I drive '07 Sierra, new body style and I'm having an issue with the turn signals.  They both blink fas like a bulb is out. I've checked all the bulbs myself, including the sidermaeker lamps in the headlight assembly. Those were blown, so I replaced them. Still no dice. Furthermore, they don't light up even with new bulbs. I pulled them again and checked them and I didn't blow the new bulbs. I put a multimeter in the socket and no juice. My thought is maybe it's a grounding issue? I don't really know though. Or even where to look if this is the case.  This is a little beyond my scope of knowledge.
Turn signal flasher/relay?  See your owners manual for the location.  It's usually under the dash near the e-brake.
Could be a bad BCM if its not wiring.
Probe both terminals to a direct ground (not to each other). This will determine if power is getting to the socket. The ground maybe switched and you'll need to backtrack the ground cable if power is present. The computer reads voltage on the ground to determine that there is working bulb.
Sent from my XT1053 using Tapatalk
I've verified that there is power to the socket. Still no dice with the blinker turning it on. Interestingly enough they come on with the daytime running lights. I figured this out after trying the lights every which way. I possibly could. Would LED tail lamps cause this? I don't know if they are factory or something a previous owner installed.
More than likely your LED tail lights are the culprit. Not enough resistance on the circuit.
There's no relay on your truck, in the traditional sense.  The process is BCM controlled; but, the circuitry buried in the under-hood fuse panel has more to do with turn signal function than you might think.
If everything else checks out, you may want to look for signs of rodents nesting within the panel, or wires chewed underneath the panel.  Also, shorts have been known to occur after rodents urinate inside there.  In this case, the panel would have to be replaced.
Edited by GhostWriter
On my 2006 Avalanche I've been noticing the plastic wire loom has been breaking off exposing the trucks wiring. Found most of this in the engine bay but a few other places underneath the truck as well and in the cab. This actually caused me to lose my gas pedal position sensor.
Might want to start taking a look at the wiring in your truck too. My truck is garage kept in the south but age gets everything.
The LED tail light bulbs are probably causing the fast blinker issue. They don't pull the amperage that the incandescent bulbs do. People have wired in resistors to make them blink properly. Also the side marker lights sometimes use as a ground the turn signal circuit. One wire is hot with the parking/tail light circuit and the other wire is getting it's ground from the filaments in the turn signal bulbs.  Then when the turn signals are flashing that's why you get the alternate flash from the marker lights when the headlights are on, because both wires are hot when the signal is flashing. When the headlights are off the side markers blink with the signals because they are using the filaments in the parking/tail light for ground. It's similar to a trailer without a proper ground and everything blinks opposite. Sorry about the long post. Not very gifted when it comes to writing. Maybe try putting incandesants back and see if that resolves both issues, if it does and you still want the LED's wire in a resistor.
The LED's are the problem. You need 6 ohm 5Watt Load Resistors.They are around 8$ on amazon. http://amzn.to/2iPT1Jh
Don't laugh at my 6year old drawing. Just trying to help! lol.
If this helps Hit the like button!
  • 3 years later...
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
