Height
snowman44
So I currently have a  2016 double cab 4x4 midnite addition with level kit with 285/50r/22 and Im looking into a 2500 hd.  I love being able to put my truck in the garage and am curious of height difference between 2 trucks.  Anyone possibly know the difference?
I have a 2017 2500 HD. 20in Wheels, stock tires, and height wise, my truck fix into a standard 2 car garage just fine.  I will add that there's not but about an inch and a half to 2-inch worth of clearance so if you went with larger tires and larger Wheels I doubt that it would fit a standard garage door
I don't know the exact height difference, but I know my 2500HD (with 1.5" lift and 34" tires) still fits in a standard 7' garage door with a little room to spare.
According to GM, the 2500HD is about 78" tall in 4x4 config. It should easily fit in any 7ft tall garage door.
16 minutes ago, snowman44 said:
WTF..Just measured from floor to top of header 6 and 7/8
Six feet and 7/8ths of an inch? or maybe 6 feet and 7 or 8 inches? Still pretty low. Mine fits in standard (cheap) house.
When my Sierra was in the shop I was in a loaner 2500 HD Sierra 4x4 SLT. Cleared the door with ease. I have a standard size 2-car garage door (7ft High)
Speaking of garage height, anyone else have their antenna hit the top of the door opening when pulling in  / backing out?
2018 stock truck heights:
1500 DC 4x4 73.9"
2500 DC 4x4 std box 78.1"
2500 DC 4x4 long box 77.8
2 hours ago, snowman44 said:
Thanks for all the feedback.  Are the 1500 and 2500 double cab with standard bed same length?
1500 dc is only available with the 6.5' box.
2500 dc is available with either the 6.5' or 8'
1500 std box - 229.5"
2500 std box - 230"
2500 long box - 248.9"
1500 crew with the short box and 1500 dc have the same length 229.5" and wheelbase 143.5"
in GM lingo
short box is the 5'8" box
standard box is the 6.5' box
long box is the 8 ft box.
So....2500 crew is not available with a short box (at least not in GM lingo)
1500 crew is available with short box or standard box.
2500 crew is available with standard box or long box.
1500 crew short = 229.5"
1500 and 2500 crew with standard = 239.5"
2500 crew with long = 258.4"
I
And a 1500 crew with the short (5'8"box) is the same wheelbase and OAL as the 1500 DC standard (6'6" box)
In early 2000's when 1500 crew was developed, part of criteria was to fit in same garage space as the ext cab 6'6" - which was the most popular pickup version at the time.  OAL and wheelbase of the 2 are identical.
Many home garages can fit a crew cab short but not a crew cab standard.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 478 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
