parking brake pad replacement
I appear to have issues searching this forum or selecting the correct search words.  Does anyone know if it is possible to replace the parking brake shoes without pulling the axle and hub off?  My parking brake setup must have stuck and heated up the rotor and made a hard spot. Nothing I do will make the regular brakes stop squealing at near stopped speeds now.  I ordered new parking brake shoes, rotors, and brakes but never worked on the HD parking brake system.  It was easy on my 1500 but this looks like I won't be able to get everything apart with the hub still on.
Thanks
What year HD?  More than likely you will have to pull the hub.  Service manual shows as such.
Should be a floating rotor?
?  Floating rotor?
?  Floating rotor?
I just did brakes on my 2012 2500hd, the rotor is not part of the hub, hence a floating rotor. Yes, that is the correct term...
Ah gotcha.  OP is doing parking brake shoes (wrote pads in his title) but to do those the rotor (obviously) has to come off, but the hub does as well to access the parking brake shoes and their hold downs and springs.
Mine didn't require pulling the hub for the parking brake shoes? Once the rotor was off, everything was right there...I pulled it apart so I could lube the friction points and never seize the adjuster. The parking brake cables were a pain...
My 2011 rotors slid off once the caliper was removed. Well can’t say that. Had to beat them off with a hammer. The parking brake shoes were rusted and locked on the rotor. When got the rotor off. I gutted the whole parking brake assembly. Gotta love rust.
If it's a GMT-800 truck ('01-'07), then the axle/hub needs to come off.  You need to replace the inner hub seal, as it's not reusable, you might be able to reuse the gasket on the axle.  And make sure the inside part of the hub seal either comes off with the hub or you remove it from the axle, as it will result in a leak and that will ruin your shiny new brake shoes.
And if you are doing the shoes, you should also replaces the various springs for the mechanism as well.  The hardware kit should be cheap as well (under $20).
Sorry forgot it is a 2013 2500HD.  Sounds like I am going to have to pull the axle and hub.  Guess I need to order a socket to pull the hub nut off as well.  Crap I should have asked this first before I ordered everything.  How tight do I need to make that hub nut?  I had the full manuals for my 2004 but didn't cough up the $150 for the 2013.  So I guess I need to get an axle seal and a seal for the hub as well correct?  Guess I should repack bearings as well, geez this is a lot of effort to put new parking brake shoes on.  Sucks since I only have 32k on it.
you don't have to repack the bearings with grease, as they are oil-lubricated (hence, the oil seal in the hub and gasket on the axle).  there is a specific process for tightening the nut for the hub, so the bearings are correctly loaded.
Thanks, gotcha on the bearings.  Watched a few videos on the process although NONE for the 2007-13 models, only can find the earlier models but assume they are pretty much the same.  Ordered a Chilton and Haynes manuals since the Helm factory manual is now $350 :sigh::sigh:.  They were only $150 for my 04 1500.  I found the axle gasket but everyone seems to just RTV the end of the axle???  Ordered the hub seals and synthetic gear oil.  Still can't find a part for the hub nut socket.  Done lots of brakes and rotors but never this so sorry for all the questions, this is my first 2500.
I wouldn't bother with the Chilton's.  I've bought a bunch of them for a variety of vehicles, and they have a ridiculous amount of generic information and only some vehicle-specific stuff.  Maybe instead spring for an online subscription to the FSM at alldata.com or helminc.com...  I bought the FSM for mine ($300+ridiculous shipping a couple years ago), then I left vol 5 on the rear corner of my truck, forgot it was there and went for a drive.  Naturally, it falls off the truck into a puddle, which then froze over (I'm lucky that way), driven over a couple of times, totally ruined.  I did get lucky in that maybe 3 weeks later, someone sold me their FSM for this truck cheap, so now I have 4 of the 5 volumes in the house as well...
When I did this on my truck, I wound up taking the nut to several stores before I found a socket that worked.  And I think I read somewhere that the nut changed for GMT900s (from the GMT800 one).
And for doing the parking brake, you want to measure the pad diameter, and adjust them so they just fit into the drum.  It SUCKS working the adjuster through the tiny hole GM has for doing it.  Driver's side is just annoying, passenger side I have to use a flashlight, mirror and custom-bent brake tool to do it...and you have to remember to rotate it backwards (cuz you are looking in a mirror), or you might rotate it the wrong way and then wedge it and have to take the hub off again to un-wedge it....
Get a subscription over at ALLDATADIY.  You can buy a pdf download or disc of the service manual from "seriousctbuyer" on ebay.  I do both.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
