Your favorite tires????
I got just over 60K on my Nitto Terra Grapplers. I wanted something more aggressive and just had the Wrangler Duratracs put on 2 days ago. So far I am impressed they are cheaper and lighter than most other tires. I am running 275/60/20 on a leveled truck.
  • Replies 66
My truck has the stock Bridgestone Dueller ATs with 12500 miles so far.  The tires look great with hardly any wear and they’re very quiet but ride kind of harsh.   The main thing I don’t like is the poor performance in light snow and packed icy roads.  In 2wd it’s slides and loses control steering too easily and 4wd auto is somewhat better but I’m still sliding and slipping too much.  They gotta go!   I’m tempted to try the new BFG AT KO2 but reviews are fairly consistent that after 25k-30k miles the wet and snow traction drop off sharply and road noise becomes annoying.  Pretty much mirrors my experience with the old KOs I had on my Ranger FX4 to a “T”.
I had had pretty good luck with Michelin LTX MS2s after the BFGs.  Better on road traction all around than the BFGs, quieter through 57000 miles I drove them.  But always had problems with rim leaks with those softer tires.  Always.  Had all four resealed and rebalanced multiple times.  Had a couple flats too.
No matter what I get , the idea of a snow rated  all season or all terrain tire sounds good if I can get at least 37000 trouble free miles (3-4 yrs) out of them.  I will say that after 50000 miles my old BFGs still had most of their tread and I never got a flat with them and there was zero uneven wear.
Put a set of these on the truck. Stock size: 265/65/18. Starfire: 275/65/18. Removed Cooper ATP, 275/65/18. Tread remaining after 21 k miles was more than half gone from new. Were getting noisy, especially at 50 mph. The ATP's were noisy and rough riding. To be expected from this design IMO. Good traction in fresh snow, not so great on packed snow. Normal? We live in the mountains of Colorado. Drive dirt roads, two lane rural state roads and highway. The Starfire is quieter, smoother riding. Bumps and road defects are felt less. My guess would be a softer sidewall. Much better highway tire. Quiet, good handling. Snow and mud traction are good. I wanted a quieter, better riding tire and the Starfires came through. May have sacrificed a little traction switching from an all terrain tire to a mud and snow rated tire. Haven't towed with them but I don't see a problem.
Update,
So far happy with this tire.
:happysad:
On 12/28/2017 at 8:16 PM, steve76t said:
cleaned her up a bit to make her a little more presentable...
Those really look good, I will for sure get that size next time around. My biggest regret with my truck is sticking to OEM size.  Those are a hair wider and a hair taller, perfect balance of looks/practicality/function.
My BFGs have 25k on them now and show no signs of traction loss.  I drove to work Saturday on snow covered roads in 2wd and never slipped once.  So far I have nothing negative to say about them.  They do sometimes make some noise, but that just tells me I’m behind on rotating them.  I’ve been trying to rotate every 5-6k miles.  Mine have worn fairly evenly, I bet I get 20-25k more miles out of them.
On ‎12‎/‎12‎/‎2017 at 10:57 PM, steve76t said:
I've decided that I need to replace my stock Goodyear LS-2 tires with something that might actually be usable in the snow.  I'm gonna add a 2" Zone level kit and go with 285/55r20 tire size. But which tire???  I have my list narrowed down to in current running order.
  1. Toyo Open Country AT-II Extreme  - 2nd most expensive at $335 each, 59lbs each, semi-aggressive tread design,  may be one of the quieter options?
  2. BFG K02 - most expensive choice at $350 each, but one of the lightest weight at 56 lbs, nicely aggressive design, good looking tire.
  3. Nitto Terra Grappler G2 - $306 each, least aggressive look, softer tread, quietest of the bunch?, may not last as long, same weight at the Toyo.
  4. Falken Wildpeak AT3W - cheapest by far at $255 each, save $380 over the BFG, also 59 lbs, aggressive design, tread life won't match the BFG or Toyos according some reviews.
  5. Mickey Thompson ATPZ3 - $304 each, "best" rating by Discount Tire, heaviest tire in the bunch at 65lbs, possibly the loudest, but love the "look" of the tire.
So with all that said, which tires would you go with?
Just my two cents because I went through this back in October. I went with the BFG KO2's but I did the rough country 2" level kit before hand, the tire size was 275/55/20 when I pulled the trigger on it I wanted 285/65/20 the difference was explained to me that was only millimeters in difference but price was an additional 80 bucks. I also bought them at Costco when they were on rebate 50 dollars off. total price was 1200 out the door. I live in a four season state and have already had snow fall and the tires did excellent. I also kept the original rims on the truck and it looks great and rides great.
There's actually very noticeable difference between a 275/55r20 and a 285/65r20 tire size.  The stock 275/55r20 is about 31.5" tall & 11" wide.  The 285/65r20 tire is 3" taller at 34.5" and 1/2" wider at 11.5".    The 285/65R20 tire is tall enough that it would probably rub with only a 2" level kit which I definitely wanted to avoid.
The 285/55r20 size I went with is a little bit bigger than the stock 275/55r20, specs only show a 1/2" difference in height, but on the truck it's actually closer to 3/4" taller.
Rough Country claims you can fit up to 32" tire, I didnt go that big but what I did go with I'm happy with and BFG's have never disappointed ever. I know they don't have a milage warranty but as long as they are rotated regularly they will last 60000 mi's or up to 4-5 yrs
BFG K02.   I have about 60,000 miles on mine with good tread still left.
My wallet likes the sound of this.  Looks like I’ll be waiting a long time to go bigger though.  Just means I have to live with my mistake longer.
None of the above - Hankook Dynapro RF10. Its an all terrain tire, with a winter tire rating. They are quiet, wear like rock, balance with very little weights, are amazing in the snow, and are very well priced.. IMO they are twice the tire of the BFG and much cheaper....
How much air do you run in them and which ply rating?
I run them at 38psi.   I believe they are 10ply.  The size is LT275/70/R18.   (33")
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
