Ordering New 18' 2500HD Denali
With the Duramax Package to replace my 15' 1500 AT.
Question is do I bother to order the Z71 Off-Road Suspension this time or just go with the standard suspension to get a less stiffer ride quality?
There is no different suspension for the Z71 option.
Sent from my STH100-1 using Tapatalk
Standard Suspension Package
  • Designed to maintain handling and ride quality while towing a trailer or carrying a load
  • 51 mm twin tube shock absorbers and 33 mm front stabilizer bar
Off-Road Suspension Package/Z71
Price  : $180
  • Gas-charged shocks
  • A 33.6mm front stabilizer bar
  • Under body transfer case shield helps protect the transfer case from rocks and debris
  • Z71 chrome front fender emblems
  • Hill descent control
That's not a different suspension. The only thing there that might change the ride is the shocks.
Z71's are Rancho Off-Road Red Shocks , not sure what the Standard shocks are but they are not Rancho Off-Road shocks.
Correct. Easily swapped out.
You may wish to consider ordering a single axle 3500HD instead.  You'd be surprised how quick a 3/4 ton diesel truck can run out of payload with a heavy trailer.  The price difference is negligible, the payload difference is not.
I currently have a Z71 Package on my 1500 that I swapped out the stock Rancho's (which are bricks) to Rancho quickLIFT Loaded & RS9000XL's that are adjustable.
Same ride, the junk Rancho shocks do not chance ride at all, they are junk and are often leaking...
I would order the Z71 package regardless.
I have the base suspension and I think it is great.  However, I also don't notice things that other people find incredibly obvious and annoying, so there's that.
Too bad the 2500hd's do not have the magnetic ride shocks that the 1500 Denali has. That would be a different ride! My guess is that it would not hold up the added load a 2500 can handle.
From the Denali section of the 2018 order guide:
Z71         Suspension Package, Off-Road, requires 4WD models, includes twin tube Rancho brand shocks and (JHD) Hill Descent Control
2500 - Requires all-terrain tires. Z71 chrome front fender emblem not included on Denali models.
3500 - Requires All-Terrain tires. Z71 chrome front fender emblem not included on Denali models. Not available with dual rear wheels.
And also:
NZZ    Underbody Shield, frame-mounted shields, includes front underbody shield starting behind front bumper and running to first cross-member, protecting front underbody, oil pan, differential case and transfer case
1500 - Standard on 4WD models only.
Standard on 2500/3500 Denali
    Daniel422
    Daniel422
  • Who's Online   2 Members, 0 Anonymous, 872 Guests (See full list)
