2017 Suburban Poor Snow Performance
Yes, it has the defroster strips in the glass. It wipes right off with the wipers/washer fluid for the most part but not around the outside around the wiper track.
It happens to EVERY VEHICLE...
It has nothing to do with a specific vehicle, it's going to affect anyone in snow country.
I followed a lot of cars home on I80 last week that were the same way, including my 2500hd...couldn't begin to see the lights, even at night. That's why I have a set of lights mounted on the headache rack...
Steve
2012 2500hd 6.0l
After searching on "snow covered tail lights", I found a few suggestions to try out. RainX and silicone were suggestions from truckers with led lights. Some Volkswagon TDI owners suggested either adding extra halogen rear running lightbulbs, adding a defroster strip, or adding rear taillamp wipers from a donor Saab or Volvo. I'll start with silicone, then move to somehow adding a halogen bulb. Maybe there is a plug in replacement if Im lucky.
I'm going to try the ceramic coating after winter. Don't have it bad like you and I'm driving a truck but I gotta park outside so ceramic seems like it will help.
Sent from my SM-N950U using Tapatalk
On 1/3/2018 at 2:37 PM, onekama_mi said:
 The stock continental tires were downright dangerous after 27,000 miles.
This is the problem I think I'm having with my 2015 GMC Sierra (Continental Contact).......in the snow, or rain, I'm getting passed by everybody. I have owned GM trucks that were much better, so it's gotta be the tires. It's a lease, that will end in October, so I'm not running out to buy tires.....unless I buy it out.
Tires will make or break any vehicle...
Steve
2012 2500hd 6.0l
  • 1 year later...
SUV bodies have lowered significantly over the last two decades, so I understand your frustration.
The plastic beard on my 17 Silverado's front bumper sustained damaged in deep snow drifts and was the most likely culprit in a botched  driveway escape attempt in a blizzard.
So I chopped off most of it.
Trimming yours up to the paint line could free up a lot of clearance.
Try some rear splash guards.  They should eliminate most of your snow blanket.
Front splash guards will keep a lot of ice and slush out of your running boards and some grease at the joints could help the cause.  Otherwise, removal may be the best winter move.
Good luck and get some duratracs!
    • Sir, economics doesn't have a moral compass. 😉 Just say'n.
    • One would think. BUT....This is what a Google search gives for the GM OLM system:    It doesn't measure oil condition save the highly indirect water temperature. It should measure oil temperature and as we've discussed they are not as closely related as one might assume. The algorithm is based on expected conditions at the end of a certain number of miles or revolutions. And sirs, this estimated value is not tilted in the engines favor. It favors the OEM's bottom line. There are no magical number of miles nor revolutions. No magical time limit. There is only what can be measured directly and only in the broadest of terms would the values used even come close to reality.    It samples nothing. It has no idea where the oil started or where it will finish given the limited values use to create the algorithm. It is just a reminder for the brain dead to do something at some time to keep the warranty in tact. Pure fiction.    Key Factors in Oil Life Calculation The OLM calculates the remaining oil life percentage based on the following factors: Factor Description Engine Revolutions Tracks the number of engine revolutions since the last reset, decreasing oil life with use. Mileage Since Last Reset Monitors the distance driven since the last oil change, capped at 7,500 miles for most models. Time Since Reset Decreases oil life over time, dropping to 0% after one year, regardless of mileage. Engine Temperature Adjusts oil life based on coolant temperature; exceeding 260°F sets oil life to 0%.
    • Towing power and I guess MPG matter that’s why I may end up going with a gear swap as soon as they’re available for this truck if I’m correct
    • If I may, I'd like to post my prediction of the trim levels for the 2027 GMC Sierra, based on what was released/introduced today about the Chevy Silverado.   Using the "Professional Grade" wording already in use by GMC, here are the eight (8) trims I believe the Sierra will offer (comparable Chevy trim in parenthesis): Sierra Pro (Work Truck/WT) Elevation (Custom) Elevation Premium -or- Ultimate (Silverado) AT4 (Custom Trail Boss) AT4 Premium -or- Ultimate (Trail Boss) AT4X (ZR2) Denali (High Country) Denali Ultimate (N/A) If GMC would rather simplify the trim levels, then I predict six (6) with package upgrades in parenthesis: Sierra Pro (with a Graphite package upgrade option) Elevation (with a Premium -or- Ultimate package upgrade) AT4 (with a Premium -or- Ultimate package upgrade) AT4X (with AEV and Ultimate packages upgrade) Denali Denali Ultimate  Let's see if I'm close.
    • I have to believe there are already a bunch of threads on this, but my searches didn't turn up much. While I like the ease of a plugin solution like the Carbyte, It appears it disables the AFM or DFM too, and is not configurable to only disable the auto stop/start. So, I'm looking at the Autostop Eliminator product. I like the idea of it better, but I'm concerned about the install and having to pull so many panels to get it installed. Mines a 2026 work truck, so from what I've read it's a less involved install, but having watched a couple install vid's, I'm still a little intimidated. Might need to buy some plastic trim tools to get it done without breaking or marring stuff. Any experience intalling in a WT greatly appreciated.
