Any issues with levels OTHER than Rough Country?
Arkangel
14 hours ago, Boardmember said:
I haven’t rolled up under with a flashlight but do I assume since I have an ‘18 I have the stamped UCAs for sure?   Or might I have the alum or steel?
Stamped
  • Replies 55
I was reading about this issue with the stamped steel control arms on ReadyLift's website yesterday. I am currently running the 2.25" level kit and am now wondering if I should be considering getting the upgraded upper control arms in the near future to replace my stamped steel ones. I haven't had any issues so far but would like to keep it that way.
I have the stamped UCAs as well and after reading the comments on this forum decided to purchase ReadyLift 2.25" kit with the upgraded control arms (just ordered this week).  I live on a dirt road and do some occasional light off-roading, so didn't want to take a chance.  A good bit more money for those upgraded UCAs, but didn't want to have to worry about driving down my dirt road and having the ball joint pop out!
Not sure if any of you shop at RDP but they have the Readylify kit with 10% off coupon code md10d
***Aluminum uppers here, 10 k miles after install of  MOTOFAB 2.5, 1"rear, Aligned AND was just told my upper ball joints are bad!
I had a 2.5 rough country level on my 2014 Silverado 1500.  It made a clicking sound when I turned the wheel and only when it was warm.   Cold it was silent.   I took it out and I've read up that a 2in level alone won't do it.   I'm debating on putting that back in this weekend.   I have aluminum arms by the way.
ReadyLift 2.25” level with UCA’s on my 17’ Z71. Been running it for about 2 weeks, rides good no complaints, although my truck is not daily driven. Still in the process of upgrading tires
So it sounds like there is a definite risk with the stamped steel control arms and lifts up over 2-2.5", but what if you have cast/forged steel control arms? Any known issues there?
Looks good! Did you measure to see if you got a true 2.25” of lift or +/-
i have had the Rough Country 2 inch level on the front of mine for over 30,000 miles without issue.  I have the cast steel control arms.  I do some off roading too here and there.
