I’ve had it 2 weeks now, I love it!
as I’m purchasing it from Range, I notice they sell one to keep it in 4 cyl more often?
Are these flying off the shelves?
I understand that it's a little cheaper, but why not just spend a little more money (<$100 more) and get a full on programmer that includes cylinder deactivation??
For instance, you can get a hypertech for ~$300. You will get this function without the need to keep something plugged in, plus you get to program everything else...
I'm just curious what the decision point was for purchasing these..
Some people decide they don't want to program their vehicle while it's in the warranty period, like me. Once out I will probably sell mine and then tune it.
I often wonder this same thing.  I have read a lot on this topic and have been driving with AFM for the past 9 years.  If it is creating an annoying ride then it needs repair not elimination.  You can see when your truck switches to V4 but but I seriously questions the complaints about feel and sound.   We should start embracing cylinder deactivation and start/stop technology because it isn't going away.   I personally think it is brilliant to have cylinders operating when needed.  No sense leaving the lights on in rooms you're not using!
That makes sense. I didn't mean the comment to be negative in any way, just an honest question.
That totally makes sense with that justification. I still think 200 bucks for that one function is crazy expensive.
So does this thing still have problems throwing trouble codes on the 2017s?  I am interested in one but I have a 2017 Sierra 1500 with the flew 5.3 v8 a heard stories of people constantly dealing with check engine light coming on.
I have one on a 2018 silverado ltz. Only been on a day or 2 but no codes yet. Figure they should pop up as soon as the unit is plugged in
I have one on my 2018 LT and have had no issues what so ever.  Been plugged in ever since I got it a month ago.
I too have a 2018 LTZ Z71 and was shopping for the disabler. I was concerned about the engine lights as well, but from what I’ve read Range appears to have rectified any issues in the 2017+ vehicles with their latest update. FYI There is currently a discount code strait from the range website offering $10 off price and free priority shipping ($189) for those currently interested.
1 hour ago, pwgsx said:
What is the current version now ?
I believe they are at 8.3 but, per Range’s website Version 7 and above should have eliminated the issues in 2017+ vehicles reference the Check Engine Lights.
  • 1 month later...
Good point about the full on plug in tuner .. I wonder if that is really worth it.
Plugged in my new RANGE AFM Disabler Friday.  No codes or problems.  Not enough time behind the wheel
to make an accurate report but the truck seems more responsive especially on the hills.
Current version is 8.6 at least as of last Friday
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
