I am looking for pictures of wheel spacers on GMC stock rims. I am debating on putting some on and just wanted to see what each size looks like (1"   1.5"     2")
thank you
thank you
I am also interested in this. Did you have any luck finding pictures?
no I have not found any pictures yet
I’ll get picks up when it’s light outside. I have 20” stock snowflake wheels with 33” tires and 1.5” wheel spacers!! It really set the truck off, made it looks much more aggressive. Plus the snowflakes have little pocket where it meets the spacer, so I didn’t have to cut the factory studs. I would recommend 1” spacers for the rear and 1.5” for the front. They don’t line up exactly. You will be the only one to notice so I wouldn’t worry to much
Edited by Ddub711
1.5" Boras on the rear to match the added width from my 4.5" Zone lift. Stock wheels and 35" Ridge Grapplers
How much rub did you have with the 4.5” lift? I’m assuming you did some trimming? I really want 35’s but the local shop is telling me I need 7” of lift.
21aee10cb452756da0c9d2460cfd71e5.jpg851629c8011ac62914bd312d665d0a49.jpgc414c9d47be05ef30e7f861fa04781d0.jpg
I went 1.5” all the way around and you can kinda see the back wheels are out a bit farther.
  • 4 years later...
Z from Southern Idaho here I just got a 2017 GMC Sierra single cab V6 2WD 8ft bed  with twenties and a lift OR leveling kit
I already tapped into the factory speakers to install a line out converter and subs
I'm ordering  wheel spacers in a day or two I'm jumping straight to 4 inches?
Will it rub more than a little bit?
Is 88 inches too wide?
Is the clearance worth losing the fuel efficiency if these are way too heavy to even function
