4" lift allowing aftermarket and factory 18" wheels?
I've done some searching and I dunno if my search-fu is lacking but I can't find definitive evidence but.....
I'm looking for a 4" system that will allow me to use aftermarket wheels in good weather, and factory wheels for winter. Fabtech uniball is out of the question due to it not having any grease boot....weather in nwpa would destroy it lol.
CST and Rough Country.   Basically, you need to use a bracket lift instead of a knuckle lift if you want to use stock 18" rims.     If you go over 11.5" in section width, you will probably rub on your UCAs and have to run spacers on all 4 corners.
It seems from what Zone's description says, their 4.5" system would work too. The tires I'd LIKE to run are 295/70's so that would be 11.6" wide
If you have stamped steel control arms zone may not work. I tried to run factory 20s on 305/55s and the nub on the UCAs around the balljoint rubbed the inside of the tire
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
I have CST 4.5” lift kit with cognito upper control arms and running stock 18” wheels 265/65/R18. I love it.
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
You have pics?
Nvm, just looked at their prices, no thanks lol
4.5" Zone
I have the cast arms
You should be fine then
4.5" Zone
If your factory wheels won't fit with whatever lift you do go with, you can always run spacers and that will solve your problem. Despite what some people say they aren't incredibly dangerous, just buy quality hub-centric and wheel-centric spacers and you will be good to go.
Well that's good cuz my main concern was getting a kit that keeps my ball joint and axle angles safe
Pics would be great
I find these trucks don't need big tires when they're lifted in the 2 - 4" range
They still look good similar to a 2500
Pics would be great
I got you tomorrow when i got some daylight
Compared to the BDS kit I thought it was cheaper....maybe not! Just trying to give my opinion and share my knowledge/experience. I got pics for you tomorrow just so you can see how everything looks
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
