Change Fluid.. Or Leave Alone?
I have a 2000 Silverado with 250K. Just got the truck not long ago, so don't know any of the history. Anyway,  I was changing all the fluids and wondering if I should change the transmission fluid. The fluid is defiantly brownish red and needs to changed, but I have heard stories of folks messing with this and actually causing problems. Especially when doing a full "flush"  ...as for me I was thinking of just dropping the pan and changing that fluid with filter.  The trans works / shifts like butter now.. it's perfect.  The truck is just a farm truck now, only driven about 3K per year.. no towing or even much high speeds for that matter.
I'd do a pan drop, replace the filter, clean the pan out well as well as the magnet.  Use a high mileage dexron 3 transmission fluid (Example: Valvoline Maxlife).
Daniel
Daniel
This.  Change it.
I have looked into this matter very thoroughly on multiple occasions over the years.
Benefits of changing the fluid:
1) The transmission MIGHT last longer with new fluid.
Disadvantages of changing the fluid:
1) Transmission might fail immediately, or sometime over the next year.
To me its just not worth the risk. If it ain't broke, don't fix it.  I have talked to many transmission shops about it, and they all said the same thing:
    If you know the service history on the trans fluid, and you know for sure that it was changed regularly - then keep changing it. If you don't know the history on the transmission, then LEAVE IT ALONE.
 Problem #1: As the fluid gets old, the detergent stops working. Crud builds up on the inside parts. When you introduce new fluid, it loosens that crud up and it clogs the valve body.
 Problem #2: If there are seals inside the transmission that are not sealing very well, the leaks get clogged by crud. New detergent in the fluid washes the crud away and the seal fails.
 Problem #3: The new fluid will be more slippery than the old fluid, so if you clutches are weak at all, then you just caused the transmission to fail by replacing the fluid.
 Problem #4: It was working just fine..... until you messed with it.......
Many people will agree with this. Many will not agree with this. There is no correct answer. I highly advise that you just leave well enough alone and drive it.
Depends what you have into the truck.  Transmission sounds like it hasnt been maintained properly so it probably doesnt have much time left.  Leaving it alone will most likely give you the longest life possible.  And take it easy on it.
Start saving for a new one.  Put the money from the fluid and filter into that.  If you change it you have the potential to lost 3 and 4th gear because of the lack of friction material in the old fluid.  Once its dirty in a worn transmission,it can be the only thing letting it shift.
It's likely already on its way out so if you have $$$ saved up to replace the tranny, go for it.  if not.. i'd leave it alone.
I own a 2002 and a 2003 Suburban. One has fluid that is brown, and clearly worn out. The other has fluid that is pink and looks pretty good. Both transmissions work perfectly. I have no intention of changing either fluid EVER. I have never had a transmission fail that had old fluid in it. I have had several fail with newer fluid in them. Change it, don't change it. - do what makes you happy.
I would change it out.  No worries.  I changed out a 2000 Silverado's transmission fluid and filter at 150k miles and it was really brown.  No issues after the change.
I had a 1999 Chevy Lumina with a 3.5 or something v6. After a ton of miles and years, the overdrive started slipping in and out on the highway. The "experts" said, "nothing you can do, just wait for it to fail". I decided to change the fluid, and it started working perfectly again. Kept it for a couple more years and still sold it for $900. Great car and I'm into maintenance so I say change it. IMHO.
Although I would not change the fluid unless it has been done regularly since new, I agree that if your transmission is already failing, changing the fluid and filter would be worth trying before you replace the trans. Probably wont help, but its worth a shot.
3.1L, or 3.8L for those years.  And those luminas were great cars.  Only thing you had to worry about was the head gasket.
I've always really liked the 3.1liter. I had a 2.8 in a 1989 Z24 that broke a crank shaft ( my fault for always hot rodding it) so I dropped a 1994 3.1 in it. Mostly plug and play too.
What a torquey engine and for a v6 they had a great exhaust note.
I learned to tear that engine down in the driveway ( the top end of the engine) replace heads, etc and have it ready for cruising a few hours later. The good old days.
Sent from my SM-N950U using Tapatalk
Ya, that was a 3.1. I had the 2.8 in an earlier car. Great engines.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
