On 6/11/2018 at 11:19 AM, crowsfoot said:
My 2013 has 17" wheels and I love them. I drive off road to get firewood so more rubber around the wheel is better. As bad as our roads are getting (potholes), more rubber works better there too!
17's are the way to go. The tires have more rubber but cost less haha. Plus that extra sidewall does wonders for the ride. I would have destroyed my factory 20's by now after all the stuff I've done with my truck.
I agree, these bicycle tires have no business on trucks.
Edited by WilliamBos
  • 2 years later...
On 5/11/2018 at 8:54 AM, L86 All Terrain said:
They might, with the new rounded F150 wheel wells. We wont know until we have one on the lot. The AT4 and Trailboss have leveling kits stock I believe so they will probably clear a 33". I have 33x12.5R20's on my current truck with a level and a slight rub. The width is the issue in relation to the factory wheels +27mm offset, not the height. I could probably fit a skinnier 34" with no rubbing, or add a 0.25" spacer to cure the rub with my stock wheels.
How can I tell if my 2019 Sierra had a leveling kit or not? I bought it used as a cert pre-owned and it has 22”x9” wheels on it. 6.2L 4WD. I need new tires probably by the end of the year and I’m looking at my different options.
I'm running Nitto terra grapplers on my 22's. No level.
Are you running 33/12.5R/22 or 275/50/r22 - or something else?  I'm hoping you will say 33/12.5/22 as I have been looking for confirmation that will work for awhile - the only BFG KO2 options are in 33 or 35" sizes, and Like that look.
If I end up with Terra Grapplers that will work, too.
@gemarsh Those Terra Grapplers look pretty clean. Ok, a couple questions if you don't mind,
What size did you end up going with?
Do the front tires rub the fender any?
how is their traction on wet pavement (reviews have some pretty severe complaints about losing traction on wet pavement)?
Are those the Terra Grappler G2's or the regular Terra Grapplers?
Edited by Puck9088
clarification
285/45 r22. G2's.
The truck lives on the farm, so it doesn't see asphalt much. Did take a trip to Tennessee this spring. Drove interstate speed in heavy rain for hundreds of miles on the way home. Never had a feeling of losing traction. No complaints of entering or exiting ramps.
No rubbing at all. Turning in and out of road ditches, deep enough to drag the belly.
Edited by gemarsh
Answering rubbing question.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
