Fox Shocks....how do they hold up?
  • Replies 61
Also I don’t think bigger shocks are over kill when talking about towing a horse trailer down a washboard rutted out dirt road. My wife was skeptical about my shocks at first. Until we went down a road she had known for 10 years and asked her uncle if they had graded the road. They had not graded the road just better shocks. I have the NHT springs in the rear still and with the custom valved Fox 2.0 with adjusters they do great on crappy dirt roads. No more bouncing, harsh, uncontrolled feeling from the rear. With about 1000 pounds in the rear I do use the adjusters to stiffen them up a bit.
Thanks for the input it's a lot to think about. I dont have a ton of $ to spend and don't need anything super fancy. I'm leaning towards the  Bilstein it seems like they will hold up decently or at least perform better then the Rancho's and last as long.
Would it be crazy to think that if i were to level the truck truck I could use the 4600's in the rear and get a set of 5100 struts up front?
I forgot to mention I already have the roadmaster active suspension on the truck. I would love airbags but sometimes I need to be able to hook up to the trailer quickly and just go without wasting time inflating airbags. I know I can get the onboard air but that makes the cost and install time so much higher I just went with the RAS that I dont have to worry about changing anything
I know nothing about that system or how it effects your suspensions properties. I can not give an educated input on it. I will say when designing a suspension or improving a suspension one must pick components that complement each other versus a shotgun effect. So finding a shock that complements the setup you have may be hard since it’s not a common suspension configuration. At this point anything you do may make it worst.
I wouldn’t do that, level the front and you may end up adding a block in the rear too which is what I did then you’ll be in trouble having to get new shocks again. 5100’s all the way around especially to match the ride geometry.
Makes sense thanks for the help. I think I will order the 5100 all around in case I decide to level it if I can find a decent price. If not I'll just go with the 4600 because I probably won't actually end up leveling it but I can dream
Heads up, Bilstein has 5100’s ride height adjustable for your truck almost two inches. So, no need to add leveling kit up front just shocks and a block in rear. Just add a 1” block to your rear and your done saving you at least a few hundred with installation. You will need new 5100’s in rear too. Approximately $410 plus tax
  • 3 weeks later...
I've been looking int that setup. If I raised the front with the 5100 would it make the ride worse compressing the sprig like that?
Nope, they ride drastically better than the stock shocks
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone w/ Bilstein and Fox
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
  • 1 month later...
Installed the 5100's all around. Wondering if I could do an Add a leaf and remove the factory block all together to give the rear a little bit of lift for towing without going crazy?
I’d research it a bit, usually adding a leaf in rear adds to a stiffer ride while empty bed. I’d add an aluminum 1” block in the rear and go from there. Personally, if I was towing with that setup I’d add the 1” and airbags with remote reservoirs in cab. Had that setup in my Duramax while towing a fifth wheel and it was great, ran 5lbs while empty bed.
I've been looking into airbags as an option also. The only thing I worry about is living in NY The winter can get a little rough at times I haven't been able to find much about how they hold up in the cold/snow/salt etc
I’d avoid them living in the snow, the install parts are not rust resistant. Stick with the addition of a 1” to your stock rear block, that what I’m currently running now with a 2.25” billet aluminum up front and Bilstein 5100’s front and rear. You want to try and keep as close to stock ride as possible which is what just adding a 1” block onto your stock 1” will do, add a leaf is definitely going to be a much rougher ride. You can just add the 1” block in rear just yourself and easy to take it off later if need be.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
