Who all has put on a E85 kit on their 2014-18 6.2l crew cab truck?
I am not here to discuss the merits, the cost, the pro's/con's of E85. I had it on my 2017 Camaro SS before I put a Procharger on it. I am looking for who has done it, what kit did you use and or who did you order it from? I searched for some threads on here but there are not that many it seems. I already have HP Tuners and the truck is already unlocked, the E85 tables are already in it. Just need the kit so I can turn on the sensor in the tune and reap the rewards from it.
Thanks in advance... Todd
Could you use the same kit you got for your SS on your truck or is that only for the Camaro and not universal for the 6.2? I got the OEM 5.3 kit for my truck.
No, you cant use the Corvette/Camaro LT1 kit on the trucks. The cars have the flex fuel sensor on the intake and the trucks is under it.
 Like mentioned above,  CJTunes seems like a good place to order from. He had a nice write up on here too.
Please follow up on this forum when you do make the swap.   I am very interested in  this but want to hear from others.  Anyway I'm still waiting for warranty to run out.
Got a link to the write up?
I used the stock flex fuel sensor and fuel lines.  Parts are about $150 and took a couple hrs to install.  The install requires replacing the fuel line basically from the tank to the rail.  You will also need to update the tune to turn on the flex fuel sensor.
Below are the pns for the install on my 2016 6.2 with an 8 spd.  The 6 spd trans has a different pn for one of the fuel lines due to how it mounts on the 6 spd trans (23171532 in place of 23171537).
Sensor            13577429
Sensor Clip     20967866
fuel line           23171537
fuel line           23171538
fuel line           20967834
fuel line           23158923
Thanks peeps, got ahold of Carl and ordered his kit and he is going to adjust my tune for the E85 since I have HP Tuners already for my truck. The E85 along with the new Katech ported throttle body I ordered should give me a nice 30-40 hp bump at the wheels. Now if I can get the wife to pay attention and only put E85 in the truck when she gets gas.
Let her know that the E85 is the least expensive fuel at the pump.  At least here it is.  $2.16 for E85 and $2.75 for regular or $3.16 for premium.
So what happens when there’s NO E85 anywhere when on road trip?
These trucks have the capacity to adjust to the fuel being used. I used E-85 locally and mid grade on trips.
I'm glad you posted this.  I was disappointed I could find a Flex Fuel truck with the options I wanted when I got mine.
I will read those other linked threads.  :)
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,241 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
