Auto 4x4 Noise
M1ck3y
Anyone else have gear/rotational noise when driving on dry pavement in Auto 4x4. Only makes noise when I give it gas.
I launched in Auto and now I'm wondering if I blew up the clutch packs. Actually I'm pretty sure I screwed something up, auto should be quite......
Every GM truck I have owned, going back to the GMT 800  2000 years with the Autotrac  made a noise when engaged, especially under throttle.
I think it is normal based on my experience.  Although I will say that my '14 sierra Auto 4wd is quieter than the previous generation trucks I have owned.
You should still be under warranty with a '17 model. You Might go by a dealer and have them check it out if there is a concern.
They all make a whining noise
I’ve launched it in auto4 atleast 100 times. It can take it all day long.
Thanks, strangely enough it doesn't seem to be making as much noise anymore. Unless your listening for it and compare it to two wheel can you tell. Really weird, because it did sound terrible/very noticeable after the run. Even after disengaging and re-engaging a couple of times.
If I had blown it up would I have not gotten a code saying 4 wheel drive couldn't engage?
Wasn't a whining noise, sounded like metal on metal rotational noise. Kind of ticking, I could physically feel it as much as I heard it. but now it seems to have toned down.
Maybe somehow it got stuck in 4wheel? Because I could believe 4hi would sound like that on pavement.
I usually engage auto 4wd when its raining around town.
It helps especially when on an incline on wet pavement at a stop light.
Unless there is snow/slush on the ground, 2HI is where you should be.
Noise is fine.  It will make noise in 4HI too.  Normal.
At what speed can u engage or u have to stop and then engage?
Sent from my SM-N910V using Tapatalk
I believe it’s 15mph or under but I can’t remember for sure. It’s in the owners Manuel. Unless you’re trying to go into 4lo then you have to be stopped and in neutral
According to the owner's manual you can shift into 4wd at any speed with a manual transfer case.
With the electronic transfer case you can shift into 4hi at speeds up to 75mph.
With the automatic transfer case the owner's manual also says you can shift into 4AWD and 4HI at any speed.
Any speed interesting
My thoughts exactly. Personally, I'd prefer shifting at a lower speed (like 15mph or less) as that is what I have always been told, but according to GM you can shift it at any speed. Now I would be comfortable shifting into 4AWD at higher speed, I still probably wouldn't shift into it above 45mph. I have nothing to base that off of, that's just how I feel about it.
5 hours ago, Sierra Dan said:
I always stop before shifting to 4 Low
You have to stop to shift into 4 low, unless you have a manual transfer case, but then you need to be under 3 mph
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
