135,000 Mile Service
02/23/2021
2015 Terrain Ecotec 2.4 I4
134,963 actual
2,559 miles this OCI
8 ounces total make up oil. for a usage rate of a quart per 10,000 miles.
Condensation in rocker cover. Temperatures near zero.
5 Quarts COSTCO Kirkland 5W30 Dexos 1 Gen 2
1 PL15436 Purolator Pure One oil filter
Usage calculated from add at miles of add per OCI. Last 6 OCI's)
1.) Quart in 600 miles Top End solvent clean. GM fluid.     AMSOIL
2.) 1/2 a quart in 1,786 miles or a quart in 3600 miles.      Royal Purple 10W30
3.) 1/3 of a quart in 2,264 miles or a quart in 6,792 miles. Royal Purple  5W30
4.) 8 ounces this oil change in use or a quart in 8,988 miles COSTCO Kirkland 5W30
5.) 6 ounces used this service for a quart in 14,363.
6.) 8 ounces used this service for a quart in 10,000. (this service)
Did a Transmission oil and filter change today. OEM filter and gasket with Amsoil ATF. I flushed a little over 12 qts out of there and added 12 qts back in. I 1st disconnected the cooler return line and ran the truck to pump out the old fluid and drain the pan. I got about 5.5 qts that way. I dropped the pan and had about another 1/2 qt or so in the pan. It was actually cleaner than I was expecting. I cleaned out the pan and magnet and the gasket surfaces, installed the new filter, and put the pan back on and torqued it to 80in lbs.
I refilled about 5.5qts and continued to flush out the old fluid. I took about 4 "purges of adding and flushing until I had 3 gallons of mostly old fluid and it was coming out bright red in the poly line. Shifted through the gear while idling and drove it around town for about 20min. seems to shift great, very smooth. I am just above 48K miles in the truck.  Its not too warm in Indiana, had a hard time getting the truck above 120 degrees. I guess the Amsoil does its job well! I just made sure the ATF was at the top of the cold mark when running. I'll continue to check level and add if needed later.
Flushed out my Power Steering fluid today with OEM. Took about 5 "flushes" After I would pump all I could out and refill, I would back out of the driveway and go wheel lock to wheel lock then drive down the block and hit the brakes real hard and go back in the garage. Neighbors must have thought I was an idiot. After a week of driving I'll flush about another QT out. Brake and coolant flush to come later this year. Now if I could just fix this damn squeak, Thinking it may be my U-joint that I just had replaced. Perhaps it was binding a bit.....can't wait :(
137,500 Mile Service
137,500 actual
2,537 this OCI
8 Oz make up oil this service.
5 Quarts COSTCO Kirkland 5W30 DEXOS1GEN2
Purolator Pure One PL15436 Filter
#8 is a projection in chart below of usage. About as good as it will get me thinks.
Oil change today.
Truck has 50k miles on it now so this OCI is just under 5k miles.
Ditched the "full syn" Valvoline and Napa Platinum filter for Amsoil SS and Amsoil filter( was cheaper than the Napa). I am interested in the extended OCIs.
I used the flush prior to the oil change and was surprised at all the little bits at the bottom of the drain pan! The truck seems to idle quieter but could be my imagination. I have only driven 25 miles but I am getting about 1.25 MPG better which is great if this keeps up because I was averaging 10.8 MPG. Time will tell. I figured out my unknown squeak btw, my E-brake grenaded in the rotor and was rubbing like crazy. All fixed now.
What's the opinion of the jury on the Amsoil flush? How about the Fuel additive they sell?
26 minutes ago, Abominator said:
Oil change today.
Nice!
The flush I recommend if you have over 50k miles on your vehicle.  You don't have to do it every time and if you are switching over from a different lubricant it helps clean thing up.
AMSOIL P.i. is really good stuff.  Only have to use it once in every 4k miles.  I have a lot of customers that use it regularly and say it makes the engine idle smoother and some have gained mpg.  :)
This past week
4b7e27a331742ccc9147aa918b898f48.jpg1fcdd16a0b283c70efde11173607ba8b.jpgf38d65ed707d97785076150ad5d33ab0.jpge6622004d977e14a6ca875073554a3ff.jpg
I changed a bit early only because the next few weekends/weeks I am gonna be busy.
Baseball season has started
You could go 6k easy.
Just an opinion Nick but there isn't a Group III synthetic I would take past 3K in a GDI AFM/DFM motor. Port injection and no AFM/DFM yea, but not these motors. I won't run AMSOIL, Red Line or MPT 30K over 5K. Repeat, IMHO.
I look at Ryan's UOA and see an oil whose 100 C vis is sitting on the floor of the 20W range. (fuel dilution) TBN is at the change point IMHO. Nitration number is where Terry flags my samples.
Quaker State Ultimate Durability and pistons look like this on 5K OCI's??? Yea, 3K is good for Group III. 5-6K the good stuff.
I wonder why they are not showing TBN or Nitration?  If TBN was 0 they would have flagged it.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
