Hey folks. New to the forum. I recently picked up my 2020 LT Trail Boss 5.3 in black and loving it. I started out with debadging. Installed a S&B cai, Borla S cat back, Nfab nerfs, Truxedo sentry ct and black lugs. I plan on installing Fuel Rebel 20s with Ridge Grapplers and a leveling kit which is TBD when my wallet thickens back up.
I'll post some pics when I'm done with the mods.
Does anyone know where I can find a black and red bowtie and z71 for the grill? I havent found anything for 19/20. Thanks in advance!
 Like this bowtie and a matching Z71 for the grill.
On 3/18/2020 at 8:43 AM, Kableguy said:
Backed into my mailbox. Anyone know the best way to remove light scratching and scuffs? Northsky Blue color.
Maybe a light cutting pad and a little compound? I really like soanex but McGuire is always a great go to, hope this helps
Putco Blade 60” tailgate LED light bar with amber turn signals, white reverse, red brake lights. No pics yet, haven’t had the chance.
Ordered the ReadyLift SST kit, should be delivered by Tuesday. Then it’s just a matter of getting the time to install it. I’m an on-my-garage-floor install guy, so it takes some organizing.
I’ll get pics of each once done.
Sent from my iPad using Tapatalk Pro
Where did you install the light bar? On the bumper plastic? Did you use the putco wiring harness
Finished the front seats on my leather upgrade. Roadwire leather. I had to order a T55 for the jump seat. This leather feels so nice and so far I am happy with how it’s turning out. I will never do this install on my own again.
Yes - on the bumper plastic. I thought it was too far recessed to go under the tailgate. I did use the wiring harness. It was super easy and a really clean install with that harness.
Taped off the plastic and ran Blackfire one step over the entire truck, wiped it down with a 12% ipa mixture to remove the fillers, applied Power Lock + sealer then followed it with a coat of Collinite 845 for a last step.
Thing looks like it just got sprayed in the paint booth. I’ll try and take a pic tomorrow.
Could you take a couple of pics? Thx
Here you go. From above, side right and side left. c032496ecfc276aa9834748ac1db83a7.jpg
f823134ca261dad2abedd7c32109bfa2.plist95df9f2d37d57c0710bb3bf96700399f.plist21c0f2900846de0d5bd717b1d5845025.plist44457b446e90efbe3a3af9d02ebf6bdf.plist
Here’s a vid. Small issue with the left turn signal. I am reaching out to Putco.
Thanks I am pretty much sold on it. With the putco harness was there any wiring splicing?
Ryan B.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
