17 hours ago, MTindall said:
285/65/r20 Nitto Ridge Grapplers - No lift - No spacers - Stock wheels
That's 34.8" Diameter
It fits - no rubbing
119601610_10103094326826642_2574998786700707022_n.thumb.jpg.e92058a3486a344eca379805f63bd2ef.jpg
Looks great!  I am going to leave my at4 as is without a level or lift.  Can anyone compare the Nitto Ridge Grapplers to K02's?  I had K02's on my '18 and liked them.  Never had the NRG's.
I had K02s on my last truck and I hear slightly less Road noise from the NRGs.
That being said - there is no guarantee the noise insulation on the trucks themselves isn’t different.
119510270_10103094312465422_3186227812565143886_n.thumb.jpg.d95c1e6af690300bba934a5f7d867ce3.jpg
Why would some AT4s come with 20s while others come with 18s? Which package dictated the difference? I have the AT4 with 18s and alot of posts are of 20s...[emoji1745]
Sent from my Pixel 4 XL using Tapatalk
18s are OEM standard 20s are an OEM option
Thanks!
On 6/19/2019 at 6:01 PM, Canmaverick said:
Just picked up My new At4! And loving every minute of it!
20x9 Fuel’s
275/65R20 KO2’s
Did u throw a lift/ level kit on this. Or is this factory??
I've read and read and I am still unsure.
I know I want to go with BFG KM3's on my bone stock 2020 AT4. IN 285 width they only come in 55 ratio which I don't want because I don't want to go smaller. I can't decide if I should just stay with the 275/65/20 or try the 295/60/20. Even the stock 275/60/20 Goodyears are only about 5/8' from the control arm.
I read a lot on here before buying wheels and tires but never found exactly what I needed, so I thought I'd post my results for someone in the future.
I didn't want 20x10s because they stick out so far and because the tires always seem to rub. I did wanted to get out from under the wheel well a LITTLE, but was limited in wheels that I liked and available offset. Decided to go 20x9 +1mm offset.
For tires I wanted wider, and a little taller, but wasn't obsessed with max height. I don't like when tires are stuffed inside, and I HATE when tires rub. Why spend $50k and then have tires grinding into plastic or worse yet, cut your truck up to clear tires?   Ended up going 295/55-20 BFG ATs. I could have possibly run 295/60s, but was not willing to risk rubbing and no returns once mounted. I've seen others run 295/60, but not on a +1 offset.  Now that I have these in there, going 295/60 with this offset would have likely rubbed.  285/60 was also an option, but quite a bit more expensive and like I said, I cared more about width than height.
End results are great. No rub and has about 1/2" clearance at full lock leaving room for articulation off road with no run. The +1 offset left plenty of room for the upper control arm. Tires are about 1/2" outside fenders.
Mileage took a hit with these heavy ass tires, but I'm pretty happy with the look.  For reference, this is a stock 2019 AT4 with a rough country front level kit.
IMG_20200925_183201.thumb.jpg.fcc911cd87c37d8aeaa1a1bf4aa39fd7.jpgIMG_20200925_183237.thumb.jpg.0369d9156c110d30e7f0cf28f5b0a1ee.jpgIMG_20200925_190153.thumb.jpg.5b56b9f081783179fda4431ac88448df.jpgPXL_20200926_204049136.thumb.jpg.168cd917a28406f9de27b40e61d3ffa2.jpgPXL_20200926_204108906.thumb.jpg.ee0d3402b3baed00263ee8d504f63d71.jpgPXL_20200926_204128110.thumb.jpg.7764768842b7de68162501d62ef5e82d.jpg
IMG_20200925_183147.thumb.jpg.b877d7397f5b32cfedd63e31b569c474.jpgIMG_20200925_143044.thumb.jpg.2d6b8674d5c2f42d3dfe3eda41dca08f.jpg
From what I'm reading on here and a FB group, it seems that no one is having a problem with the Motofab 1.5 lift. Has anyone experienced an issue? Like ball joint,etc.
I have had the 1.5” level for a year now and about 12k miles. I would still like to upgrade the UCA just because of the failure’s I have seen on FB but you are correct all the one’s I have seen failed are 2” level spacers which is what may be helping my controls stay okay so far. Hope it stays that way until I upgrade
I've had mine on for a while now, almost a year and a ton of miles... with no issues. For sure the ones I've seen are 2inch RC ones. Only 2 or 3, but there was also a guy with a completely stock truck with an issue. About to need tires and was about to go a little beefier ones.
    scotthvac.net
    scotthvac.net
  • Who's Online   1 Member, 0 Anonymous, 510 Guests (See full list)
