The tires aren't rubbing any components in the front? It's close with factory tires.
Sent from my GM1915 using Tapatalk
13 hours ago, CDub said:
After installation of Zone level kit at new tires694271A6-9F04-42D1-9F00-4E2C01539480.thumb.jpeg.b52b9c2d6826f7213cefa8d1fe368c35.jpeg
The tires aren't rubbing any suspension/steering components in the front? The stock tires are pretty close already. Can you please post a picture from straight on to see the side profile? Looks good man!
Not at all. Very happy with this set up.
No rubbing inside either.
Thanks for the info and pic. Looks good!
Thanks wjs4!
I know my truck is an LTZ but I had GM add the factory Trailboss lift a few months ago. Today, I installed the 1.75 inch leveling kit from Readylift and love the stance. I hope this kit works out with no issues. The product number on Readylift's site is 66-3921
What size tires are you running on the stock rims? Any spacers?
Ditto. Truck looks great man!
I just installed a leveling kit from zone off road on a 2019 trail boss and the top spacer should have a smaller hole in it so that the upper strut mount rubber cusion has something to rest on instead of a 5/8 in gap between the top mount and frame this looks like a upper strut mount failer problem down the road
On 8/21/2019 at 3:47 PM, CDub said:
Thanks wjs4!
Got my zone offroad kit installed today. Still on factory wheels and tires, but that's next
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
