You can cut off any threads that come out the backside of the tightened open faced nut without affecting the strength.
The only real safety issues regarding spacers is
1. slip on spacers (the ones that dont have its own studs) these spacers essentially increase the thickness of the wheels and less threads get engaged.
2.  using adapter style spacers that are too thin.  When this style of spacer is too thin the factory lug nuts stick out past the face of the spacer and prevents the wheel from sitting flush against the face of the spacer.  This is the scenario when you would have to cut the stud so its behind the face of the adapter or the wheels need pockets on the backside between the mounting holes to accommodate the protruding studs.
3. Spacer out of balance.  The spacer is part of the rotating assembly along with the rims+tires.  If the spacers arent balanced you will have the same symptoms as your tires  being out of balance.  The only solution to this is to buy quality spacers.
4. Wrong hubcentric size.  If the adapter hub size is larger than the wheel it will prevent the wheel from sitting flush this is a very unsafe scenario.  If the adapter hub size is smaller you can get a hub ring to make up for the size difference.
So your what your saying in number 2 is what I’m thinking I would do because I am really wanting to use a 1” spacer which will mean that about an 1/2 of stud sticking out. I’m thinking I can cut this but your saying this is unsafe?
No I'm saying its unsafe if you don't cut the studs and it prevents the wheel from being flush against the spacer.
This picture shows it better.
lugshave-jpg.732871
As it stands the factory studs stick out to far.  To be safe he either needs to cut on the red line or make sure the rims have pockets deep enough.
the pockets are indentations on the back of the wheel between the mounting holes ex:
lugshave-jpg.732871
Yea that make sense, this is what I’ve been looking for an answer too. Do you have spacers that you have had to cut the studs on your truck?
No I'm just looking into spacers for the truck but I've dealt with spacers for tons of other vehicles.
seems I'm gonna go with 1.25" and 1.5" spacers to square up the stance and according to earlier in the thread I shouldnt need to cut any off the studs.  But I'm still gonna un-mount one of my rims and measure for myself.
If you want to cut the studs mount mount the spacers up and mark on the stud where you need to cut.  Remove the spacer but put the nut back on and thread it all the way down to the hub.  Make your cut with a hacksaw or cutoff wheel then back the nut off which will straighten out the threads for you.
On 1/25/2019 at 3:07 PM, CovetedStyle said:
Yah brother I see it, it’s just not something that jumped out at me until I tried to get a picture of it.  I just hear some guys say you have to get wheel spacers the truck looks f’d without them and I’m just saying in my opinion it’s not that big of a deal to where I think people are going to notice it driving down the street.  I know you said you had pretty good success with yours so I might look into getting some I’ve just seen all the horror stories that everybody else has with wheel spacers letting go and seeing your wheels passed you on the freeway Lol
Yours doesn't look like there's as much difference as mine had, could be the tires like you said. You could measure (even approx) how much tire is sticking outside the fender and what's the different front to back. I don't think the front and rear fenders are exactly in-line with each other, but it was part of how I decided what size spacer I wanted.
I really try not to tell anyone how to build their truck. If you don't notice and don't mind, save the $100 plus. Personally, not only did mine bug me before the spacers, but I also still chuckle a little at the many trucks on the road (especially the dealer or '____ package') that don't even out the track width. Very noticeable to me and makes the truck look incomplete. Again, you do you. Hardly anyone will notice and most of us don't lift our truck to make other people happy, so who cares what they think. I might have one of the least liked builds on here because I didn't trim to stuff 35's under it, but I effin love it!
Also on the spacers, part of the deal for me is checking the torque on the spacer at every rotation. I never said a word to my tire shop (wanted to see what they'd do) and in 4ish rotations since the spacers they have torqued them while the tires were being balanced every time. Between that and buying good spacers to start with, I have no second thoughts about running spacers.
Bora could be up to 500 a set (4)   one of my foremen ordered them paid 450 and they make them specific.   About 4 weeks lead time.  I think it will help his truck too.
I just looked back and mine (BORA) were $180 for a pair including shipping (CustomOffsets.com). You have the lead time nailed though, it was 3 weeks from order to ship date, and almost a week in transit.
Looking to see what Summit has, but they don't list anything for my truck.  2018 Silverado Z71.  Has a 2.25" level kit in front and a 3" set of lift blocks in back.  Nitto RidgeGrappler 33's installed on the stock 18" rims.
Have very slight rubbing at full lock, but more than that I just want a little better stance.  I am reading here that the bolt on spacers are best, and to get them thick enough so that you don't have to cut the stock lugs.  I also don't want to go wide enough that I have to worry about wearing out bearings prematurely...
So what is the best balance here?  1.25?  1.75?
Anyone got a link to what they go from Summit?  I can drive down there but looking online, not sure which ones I need.
Look into BORA spacers
so im taking from this is that instead of me buying a full set of 1.75 spacers, i should get 2x 1.75(rear) and 2x 1.50(front) so over all my wheel stance should be equal visibly. sooo. would this now have any affect on how my truck handles other than just appearance. like body roll/tracking/cornering etc
When I got the Bora spacers on I noticed that my truck tracked differently on my normally traveled streets. Not a big deal but noticed some different pulling from side to side on occasion due to swells or dips in the pavement. A bit disconcerting at first but got used to it like the typical place for a bump in the street or the transition on a bridge, you prepare for it once you know it's there. Cornering and all that typical handling remain fine. I run 2" all around.
I’m running 1” on the front and 1.25 on rear. (With stud trimming) and they run “visibly” equal. I believe that you will have to get at least 1.75 spacer to keep from trimming studs, depending on what wheel your running. Some wheels have “pockets” to allow for some of the studs to set in without trimming excess that is sticking out. I agree with purchasing quality spacer like bora.
My only thing that bugs me about my truck is that the drivers side literally sticks out like 5” to 3/4” more then the passenger side. Like if the body of the truck is not sitting center on the frame. Weird! But I haven’t done much research so I’m betting this is pretty normal on most GM truck. Hope this helps! Good luck
    BrandonFranceschi
    BrandonFranceschi
  • Who's Online   4 Members, 1 Anonymous, 1,533 Guests (See full list)
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
