I talked to my local Line-X shop today. Very nice guy and very knowledgeable, however he told me he could not get the Chevy emblem for the bed bulkhead. He said if I could get that piece he could make it happen. The question is where do I get that bow tie emblem from?
Called my dealership, they could not find a part # so referred me to Ultimate Linings like Newdude said in an earlier post. They told me that there is no part # that the dealership could go on their website and request one for me IF my factory bedliner was tearing up and I had to submit pictures. Seems very difficult to get this piece.
All I want is the form, the funny thing is that she said it was only $10 + shipping. Hell I’d pay $25 for it if someone could help me get it.
Hey if anyone has the factory spray in bedliner on their new Silverado with the chevy logo, can you tell me how wide by how tall the chevy bowtie is?
Check your inbox.  Posting here too.Screenshot_20181029-184819_Gallery.thumb.jpg.102d53221ba7118f8e959d573042dc3c.jpg
Purple: 13 5/8"
Blue: 5"
Red: 5"
Yellow: 2 7/8"
*Note:  These measurements are of the front side that is protruding.  The back side that is against the bed wall is slightly bigger as it angles slightly going from front to back
  • Like 4
Well I have not received the actual emblem I have been creating, but the 3D printer I ordered it from just sent me this picture of my rendering. When I receive I will do measurements like Z1Boss did.
The only thing I did not have was the thickness of the one in the truckbed.
What are yalls thoughts?
-Big E
Purple: 13 5/8"
Blue: 5"
Red: 5"
Yellow: 2 7/8"
Yellow- 12 1/4 Inches Wide
Green- 3 1/6 Inches Tall
and I made it .75 inches Thick
It shrunk just a tad after production from the original size But I think it came out pretty cool. A little different looking than Boss’s but I think it would look cool covered up by some Line-X in the truck bed.
Give me your thoughts
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
