Dash Switch POD swap for bigger???
I have a 2018 2500HD work truck and the OEM switch housing under the climate control on my truck only has two switches, traction control, and cargo lights. I am wondering if anyone has swapped the switch module out and replace with an OEM one that has more switches you can use? I want to add some LED lights on the front and back, and would prefer to use the factory integrated switch like the 2nd picture
1st pic is my dash, 2nd is switch housing with more switches
any info is appreciated
5be1b04051532_MydashCapture.PNG.e3dfb7f085b076e9d9baac89dc7ac1bf.PNG5be1af62acfa8_multi-switchcap.PNG.0936722422100ee1da8a530bfeff4aac.PNG
haha, yeah. Read that thread. We'll see you in a couple weeks when you are done.
short story, is it can be done, but its not a simple plug and play. You will likely need a new fuse box with connections for the additional switches. Your truck may or may not have wires in place, maybe you'll be lucky since its an HD. Some of them only run a signal to a relay, so depending on your wiring expertise that may or may not be something you want to work on.
I got all excited about adding switches to my truck, but once I realized I didn't have the right fuse box and how complicated it was, I'm still sitting with my factory 3 switch plate.
If it actually works for you, post a follow up!
I got this one collecting dust if you want it
I added the upfitter switches to my truck to control a variety of lights.  My truck wasn't pre-wired for them but its pretty simple if you just want to add your own relays.(and you get the benefit of hooking them up to function exactly as you want)  all you really need is the upfitter switch, some terminals to go into the existing plug going to your current switchset.  A long 4wire cable to go through the firewall, and 4 automotive relays.  I mounted my relays to the firewall behind the battery out of site with some industrial velcro and one ziptie and ran all the wires in the trucks existing wire loom.
The yel,red,grn, and gry wires with white stripe are the 4 spots you need to insert your 4wire cable to. (this is the connector that plugs into the back of the switch bank.
I pre wired all my relays so its was only a few wires I had to hook up into the truck.  (I have 5 relays because I wanted to have one as a master that turns on all the lights when i use the high beams, but I can still control each set of lights individually)
The switches actually switch to the ground so it should be hooked up as follows if you just are going with the 4 relay setup. (relays should be NC type)
relays have 4wires, Coil+ , Coil -, Line, Load.
-Connect all 4 COil+ and 4Line wires to a power source (be it straight to the battery or to a Retained power source depending if you want to be able to use it with the truck off)(its also a good idea to hook a fuse up in line with all 8 of these wires)
-Each coil-  goes to one of your 4wires in the cable you ran to the back of the switch inside the cab.(that terminates into the block shown above.
-Each load wire is now controlled by the switches and you hook your 4 loads up to the remaining wires.
Finished Product.  I would avoid going with any of the other million switches for the different options as some of the other functions only send a momentary pulse and require even more work and parts to get working properly.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
