Just ordered them. Having them put on Friday!  Thanks you all!!
How did that size turn out? I know the chevys have a bigger wheel well. I want to get bigger tires on my winter setup.
I have the At4 with level and 285x60x20. I had to remove fenders and cut metal unfortunately they still rub. But I have 20s with a negative 25 off set.
I plan in on putting the stock rims back on in November before Winter hits. Still unsure what size tire I will put on the stock rim.21d8af5339ba24a67464f5b2a9a6c8af.jpg
how rough are your winters? stay with a narrow tire for the winter - maybe a 275/70/18 or similar
I didn’t order the 305s. Just the 295/70/18. They are suppose to be delivered tomorrow
On 9/5/2019 at 1:56 PM, Mike Potts said:
Yeah I like them, I was concerned on the weight of each tire. As aggressive as they look they are not that heavy.
Mike. Did you have yours road force balanced?
I’m still having violent shaking and vibration. Not as bad as the 35s I had.   I don’t know what the deal is. I’m going to see if they can road force balance them.  Can they do that for a mud tire?
Would it help any?
Yes they can.
Did you try balancing beads?
Same place or different place doing this work?  Looking like it might not be the tires.
I have a slight trembling with the stock tire/susp set-up to be honest.
I always blamed the roads, and the fact that you can feel so much more in these trucks.
You're in a custom too, correct dctackett? It may be a TB custom issue, or those shitty ranchos.
I’ve been ton3 different shops. I tried balance beads with the 35s I had and it made it worse.
Im pretty sure it’s just tires because the duratraxs I took off they was little to no shaking or vibration at all.
Yes 19 custom trailboss.  I’m gonna let them roadforce it and maybe look into aftermarket shocks.  Any recommendations on which brand?
yes, always roadforce balance them. LT and 10 ply tires suck to balance.
Take it one step at a time. You just swapped tires because of this issue, don't buy shocks right away before exploring all avenues!
Is the vibration coming from the back or front ?
   Ive got no vibrations running 35x12.50’s (Sunfull Mud Terrain) / Fuel Coupler 20x9 wheels on 2019 custom trail boss / Rancho shocks in front / rough country shocks in the back ./ 4” rough country lift with the 2” Chevy lift.    Shocks wouldn’t cause vibration , just absorb bumps.
Sounds like a broke belt In a tire of a bad wheel .
Have you tried different set of wheels ?  I didn’t read all the comments but I thought I saw you tried different tires .
Yea. These are my second set of tires.   Is there a for sure way to know if a belt is broken in a tire?
Im going back to this shop to have them road force balance them in the morning, would they be able to tell if a tire is bad when they put it on the machine?    This is what I get for buying tires online... again lol
Guess I should of researched first lol. But I don’t see any lumps on the tires. Could they be “ out of round”. Not really sure to tell on that one
Well I’m going 2 hours away to a shop that has a hunter road force balancer on Wednesday to see if they can help with the balancing issue.  I understand they should be some vibration because they’re a mud tire. But what I’m getting is enough to drive someone insane lol.
They said 25 dollars per tire to put it on the machine and balance or 50 dollars a tire if they have to turn the tire on the wheel  (guessing that’s match balancing).  Anyways.  Hope this works. As I’ve spent close to 2000 on tires all together lol.
Mean while you can try sending the front wheels to the rear and if the vibration is less then you can narrow it down to those tires/wheels.
Do you know if that roadforce balance machine will tell you if a tire is bad and needs replaced?
    daveishi
    daveishi
  • Who's Online   0 Members, 0 Anonymous, 1,166 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
