Is the visor and the hood the same thing here?
Also anyone think there would be any issues with the listed HUD and an ‘18 model diesel? When I look up that part number, more times than not it stops at ‘17 in the descriptions.
Regardless. I would probably be interested in the dash HUD visor or whatever it is called.
Yes
the hood and visor is the same thing.
The only reason I referred to it as a instrument hood. That is how it is listed on some of the GM part sites
i think if you can get White Auto and Media to get the instrument cluster to work with a diesel. Then I think it will work. The only thing the HUD does is display the information sent to it by the instrument cluster.
I’d most likely be in
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
Sweet. I most likely will be in as well. Family member had a Buick and I freaking loved the HUD.
On 12/9/2018 at 8:14 AM, Viktorrocks15 said:
Check your windshield for hud acoustic sticker if it does have them you have the right one., keep in mind that 14-18 Silverado or Sierras didn’t come equipped with HUD functions.
Where did you source your windshield from?
Local windshield installer. Tahoe, Yukon and Silverado share the same Winshield part.
I could not find anyone in my area to reproduce the instrument hoods for me. I am going to try and do it myself. I am using one of the instrument hoods I received from Viktorrocks15 as the template. I will update the forum ASAP
Thanks for the info. I’ll be sure to ask for one for a Tahoe or Yukon.
Get one of those new 3D printers make your own hood. It'll be interesting to see what does retrofit will cost once it's completed and then is it worth it? Keep us posted on the cost side, especially if you don't have the HUD windshield
I will be glad to answer any questions about the HUD or send pictures. If you want to private message me.
What did you end up doing for the hood fabrication?
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
