Ordered 2 months ago, no build date yet...
I placed an order for an AT4 a little over two months ago, and the order still hasn't been assigned a TPW.
The dealership has a call with their GM rep on Monday and they hope to have new information for me, right now they're telling me that they're being told that GM is building inventory for the launch, and they assure me that none of their other truck orders have been picked up either and mine is at the top. Feels like BS to me.
I think I have a pretty good deal...I'm paying dealer "invoice" + $695, and they offered to give me their care package which includes $50 service vouchers every six months for life (almost free oil changes), access to a free rental car whenever the truck is in the shop, and various other benefits, to compensate for the lengthy delay in the order.
Would it make sense to approach another dealership to see if they can commit to having an order allocation and be willing to match the price? How aggressive should I be with the sales person I'm dealing with at the current dealership? I don't want to be a dick and blow everything up if the order is just around the corner, but I feel pretty justified in being frustrated.
I ordered an AT4 about a month ago and was assigned an event status code of 3000 and TPW of 12/3 in LESS than one week of placing oder (i.e., about 3 weeks ago).
I ordered my AT4 on 8/23 and it was assigned TPW of 10/22 the same week I ordered and arrived on 11/15. It would have been sooner if I ordered a crew cab but double cab production started later.
Sounds like your dealer may not have allocation...
Waiting is the hard part... mine was built 10/8 but it still hasn’t arrived at the dealer yet. It’s a crewcab short box so it isnt even one of the later run of trucks... I’m told now it could be ready the last week of November.
Oh and the Dealer is Dave Smith in Idaho who claims to be the largest GMC dealer in the northwest so they shouldn’t have trouble with allocations or volume...
I put in a at4 order in last week I will let you know if it gets picked up.
Sent from my SM-G965U using Tapatalk
  • 3 weeks later...
Does your dealer have an allocation to place an order?  I ran into this issue with my 2010.
Find a new dealer.
I order one May 28th at a dealer and I never got a TPW for it so I canceled it August 31 because I ordered through another dealer on August 18th and 2 weeks later I got TPW August 31..
Both trucks were identical.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
