Level kit install
20 minutes ago, jericbarg said:
That is what I would do also.
A set of 1 inch blocks with u-bolts is only $50 shipped TYD.
Easy and inexpensive  fix.
Where do you get your parts from?
  • Replies 107
I make most of mine, but Streetrays or JEMCO suspension are the 2 best.
Streetrays has an ebay store, $50 for the 1 inch lift with u-bolts.
On 11/21/2018 at 5:15 PM, jericbarg said:
Garage day was at my house today.
I helped a few friends in our group install level kits on their 2019's with some interesting discoveries.
All trucks were purchased this week.
2 HC's only needed 1 1/4 lift to be perfectly level, yet my Son's HC needed 1 1/2.
A Trail boss needed 1 1/2, Sierra AT4 needed 1 3/8.
Yet an LT needed a 2 inch spacer to be "just about" level. Still has a very slight rake.
I installed a 1 1/4 on mine which by choice left a very slight rake, when I hook my boat up it makes it level.
Seems to be most  of the NBS can get by with 1 1/2 front spacer and be level, 2 inch would be nose high.
All of these trucks with the exception of the Trailboss and mine had fender lip to ground of 38 1/2 inches all around AFTER level kit install.
Did not get to measure Trailboss post install but I will soon.
Busy day but lots of fun as most of these guys have never turned a wrench before.
So are the spacers from a 2016 the same? I was told the struts were different. Thanks
19 hours ago, StevenStarke said:
Alignment required after install? What’s easiest way to do it?
I have the same question. Anyone?
Yes, an alignment is definitely needed after leveling a truck.
Absolutely on the alignment!
ADJUST THE HEADLIGHTS TOO!
Sent from my SM-G965U using Tapatalk
  • 3 months later...
How did the leveling kit work out on the Trail Boss. I just purchased a MotoFab 1” & 1.5” kit from eBay. Figured I’d see which one works the best during install. Although, all the manufacturers, including MotoFab, say the leveling kits won’t work with the Trail Boss
  • 3 weeks later...
Any issues with aligning after leveling?  I put a 2” lower strut level on my RST and the alignment shop wasn’t able to adjust the camber.  It’s running -4.7 on both front tires.  The truck is a little nose high right now by almost 3/4”.  I’m going to change it to a 1” level this weekend.
Any feedback yet?  Have you tried to install these yet?
I installed the 1.5” MotoFab with no problems at all. Been running it for almost 2 weeks. Angles on everything looked good.  Now I’m about to purchase some Fuel Vandal 20x10 -18 wheels with some 305/55r20 tires. Still deciding on a tire.
Haha that’s crazy that’s the exact wheel I am looking at too, although I was looking at the 0 offset cause I was unsure of the level working and if the -18 would fit without level.  But I think I am getting closer to doing the same, at least it can work until A real level comes out.  I was going with the Nitto Ridge Grapplers 305/55r20 but also looking at 295/60r20 as well.
Did you get your wheels installed yet?  Curious as my shop talked to a fuel rep and he says they will still rub.  I’m so confused, not sure what to do.
    tblt44
    tblt44
  • Who's Online   3 Members, 0 Anonymous, 547 Guests (See full list)
