fe8745fadbd639b2ef87650488f8217b.jpg85a6aa025e2b3cd3630c64faeb0ebae5.jpg0bf9adc82b43f39585ec363dd95be4da.jpg
My friend just put 35x12.50R18 BFG KO2 (34.50x12.50R20) tires on her stock 18” wheels with no lift or leveling kit yet with very little to no tire rub.
18d0041a1056e69f354704948403efc8.jpg3c036b305be5828332c0ec7fe84e567d.jpge102db97f0d551e44023a65a0fa26558.jpg
I just put 285/65R20 BFG KO2 (34.50x11.50R20) tires on my stock 20” wheels with no lift or leveling kit yet with very little to no tire rub.
Anymore pics of the 20” setup?
thanks to everyone posting info and pics, helped me make up my mind. I'll be ordering 295/70/18 for my custom TB.
Seen some horror stories around the level/lifts and upper ball joints literally falling apart in no time. So, I'll let them come out with a decent kit and run this size for now.
any of you guys do a 75 profile on 18in wheel ? I like the 295/70 but was thinking about 285/75 for a little more sidewall
That's a fairly odd size tire, you will be limited to certain brands. I think that's the reason for majority of choices being 295/70.
I agree with you, and would prefer more sidewall too, though.
So 295 70 18's will fit on a 2020 trail boss with no rubbing at all? Not even at full lock?
3 hours ago, Martin Joseph Herrera Jr. said:
what is everyone doing about the speedometer being off after getting bigger tires?  My last truck had a custom tune and I was able to re calibrate the speedometer but I am not sure it will work on the new truck.  Gonna be going with 35s most likely when the current tires wear down
65mph reading will now be 69mph actual. I guess the question is, is that of concern?
It's about a 6% increase.
So I installed a set of 295 70 18 falken wildpeak at3s. And at full lock they rub. Just slightly, maybe not even enough to worry about but they do rub. So everyone that says they don't, they most only drive their trucks straight. They were installed on a 2020 lt trail boss with factory lift.
Mine only slightly rub at full lock when reversing. Everything else is smooth with no rub at all. I run this setup...
Toyo Open Country M/Ts 285/75R17
Method MR312 17x9
ReadyLIFT “1.75 Level Kit with UCAs for Trail Boss / AT4
Method MR312 17x9
Looking good! Wheels really pop with the front end! Nice truck mate
On 10/21/2019 at 1:57 PM, xAISxCR34M said:
I was able to fit 295/70r18 Nitto Ridge Grapplers on the stock wheels. No rubbing what’s so over. They fit perfectly.
Is this truck leveled? Or stock up front?
On 2/18/2020 at 7:50 AM, xAISxCR34M said:
It’s is stock up front
Love the look and interested in swapping out the duratracs for these when I get my LTTB.  How did the bigger tire change your speedometer and mpg?
It’s off by 3 mph and I’m getting 14.7 mpg at the moment.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
