On 2/10/2020 at 5:54 PM, TheTicketTX said:
Mine only slightly rub at full lock when reversing. Everything else is smooth with no rub at all. I run this setup...
Toyo Open Country M/Ts 285/75R17
Method MR312 17x9
ReadyLIFT “1.75 Level Kit with UCAs for Trail Boss / AT4
Looks great! Any impact to performance with the bigger/heavier tires?
Mpg went down a tad, other than that.. nothing!
Good to hear. Do you have the 3.23 or 3.42 rear end?
On 7/11/2019 at 2:10 PM, Dalemouse said:
fe8745fadbd639b2ef87650488f8217b.jpg85a6aa025e2b3cd3630c64faeb0ebae5.jpg0bf9adc82b43f39585ec363dd95be4da.jpg
My friend just put 35x12.50R18 BFG KO2 (34.50x12.50R20) tires on her stock 18” wheels with no lift or leveling kit yet with very little to no tire rub.
18d0041a1056e69f354704948403efc8.jpg3c036b305be5828332c0ec7fe84e567d.jpge102db97f0d551e44023a65a0fa26558.jpg
I just put 285/65R20 BFG KO2 (34.50x11.50R20) tires on my stock 20” wheels with no lift or leveling kit yet with very little to no tire rub.
I know this treads a few months old but hoping you see this and reply!
For your friend who put the 35x12.5x18s on her truck stock. Can you explain what a little to no rub is? Are we talking rubbing when turning full lock? Or just in reverse full lock? Just curious. I can deal with it in reverse only but prefer not to rub with going forward.
On 6/17/2020 at 6:31 PM, RedHoodTrailBoss said:
On a stock Trail Boss, no level and stock rims would a LT295/70r18 fit with no rub? If so which tires have been tested?
295/70/18 Stock Wheels Nitto G2 Grapplers. No rubbing and drive better than the Goodyear stock tires. I do have a Rancho Leveling kit, but the tires were put on and run for at least a week before I had the kit installed. Either way, perfect without any problems.
Is that pic before or after the kit? Also, what type is the Rancho leveling kit and how big is it? All I’m finding are the kits for non Trail Boss models
That is the picture after the leveling kit and tires were put on. Whoops on the Rancho. I meant Rough Country. Sorry. It is a 1.5 level. Here is the link: https://www.americantrucks.com/rough-country-silverado1500-150-inch-leveling-lift-kit-1321.html?utm_content=AT Lift Kits - Leveling Kits and Body Lifts|Rough Country&T5_Var4=S114086&utm_campaign=ATS+Silverado+Brand+%26+Vehicle+Low&dialogtech=ppc&utm_source=bing&utm_medium=shopping&T5_Var2=shopping&T5_Var3=red&msclkid=e7bc51f603d714af4d340ef448d401d2&utm_term=4577816664592493&gclid=CI6D2u-Lt-oCFV2rxQId0O8CXw&gclsrc=ds
On 10/21/2019 at 10:57 AM, xAISxCR34M said:
I was able to fit 295/70r18 Nitto Ridge Grapplers on the stock wheels. No rubbing what’s so over. They fit perfectly.
 I want the same tire but I was told that the tire is heavy and it would ride rough. How does it ride? Thanks
295/70/R18 Falkens on stock rims and stock height. Decided on Falkens since they were buy 3 get 1 free and had good reviews. I kept reading on other threads about stock UCAs failing on level kits so I think I’ll hold off for now even though the front has a rake. 01d1f0ddd7678910013613364d3ad13c.jpg
Is there any rubbing? Do you have any pics at full lock inside wheel well? it looks good!
Factory Trail Boss suspension.
1.25" BORA spacers.
35x12.5 BFG KO2s.
Removed mud/aero flaps. Removed front wheel well brackets. Pinned back front wheel well liners with self tapping screws.
Almost no rub. Tire kisses felt liner at full lock.
Thanks to @Ryguy and everybody else who posted on the forum.
    Bulldogger
    Bulldogger
  • Who's Online   4 Members, 0 Anonymous, 791 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
