Anyone else having any issues with infotainment screen doing strange things, I've had this issue with the bottom of screen on three occasions now. First time was when I was driving home from dealer, shut truck off and restarted and it was ok, about two weeks later it did it again and stayed that way all day, next morning it was ok, did it again today and so far has stayed that way. also started getting message on DIC that steering assist is reduced, service ESC. The lines on the camera when truck is in reverse also quit working. Just got a survey from GM on what I think of quality, think I will hold off for a while before taking it.
This is a complete shot in the dark, swag, out of left field, whatever guess...
The last generation had a number of quirky electrical and computer problems that were traced back to a bad ground (matting or insulation under the dash preventing clean contact?)
Could this be happening here again?
M.
I'm willing to bet hardware wise that infotainment setup is the same exact one i have in my 2014. Keep adding onto older gen tech and it's bound to give issues. That looks more like a internal graphical glitch then it being a faulty ground.
I would take that back to the dealer and have them service it under warranty. They will most likely swap out the unit for a new one.
Going back to dealer next Monday for that and a couple of other minor issues.
Not the kind of news I was hoping to find on this forum. Geez. I just got my truck 4 days ago. Not even 300 miles on it yet. Driving down the road today the Infotainment system rebooted.  Screen went almost entirely black with a very small type "System restarting". A bit disconcerting since I just watched a GM video last night about how the update process works - and it claimed it would never reboot while you are driving.
It came back up and is functioning, all except for no longer displaying the outside temperature.
Is this what I can expect from this truck? I have a long trip planned 2 days from now. Should I take my 11 year old Nissan Frontier with 157,000 miles on it?
Mine did the same tonight, and all my info settings were wiped out. Had to redo all my settings when it slowly rebooted itself while driving 50 MPH.
I am having issues with the screen on the dashboard... sometimes, when I first start the truck, while the Chevrolet emblem is still displayed, the screen flashes. All else seems to be working, but this has me uneasy that a bigger problem is lurking...
Mine has been doing the same thing. There is a software update that the dealer can do that supposedly fixes the issue, I just haven't gotten there yet.
51 minutes ago, KozzyJr said:
It’s what happen when you buy a new model year.
Thanks for your extremely helpful reply...........
  • Haha 2
Your welcome. Not gonna lie you made me chuckle pretty good today. In all seriousness tho, guys are buying a new model year truck experience some issues come to a forum and rant about issues. It’s a risk you take. I know I’ve been there when I purchased my 2014 and now my 2018 L5P. Life’s too short to bitch and complain about. In the end it’s just a truck and it’s just money, trucks can be replaced and money can be made. Don’t sweat the small stuff. That’s what warranty and the dealers are for. If your not getting the survice or the dealer is dicking you around change dealers. Everyone has that option. If that still not solving issues switch brands. I hope your dealer and everyone else that has a 2019 gets there trucks all solved and taken care of. I didn’t mean to cause any waves.
In all seriousness it's hard to take you seriously when the only person ranting on the thread you complain about ranting in is the guy with only one post.
There is multiple threads and post about different issues that have occurred with the new 2019. Ps I’m not complaining about anything or anyone. All I did was state a simple fact. New model years equal issues and bug. That’s what warranty is for.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
