I am tall and my wife is not. The adjustable pedals on our 2016 are used quite often.
I was looking at the 2019s and I don't see anywhere in the option packages to add power adjustable foot pedals. They are pretty much standard on many 2019 Dodge Rams trims. Did GM really leave off the power pedals or am I just going blind? I don't even see it on the high country trim?
Nope, they are gone, not available no matter how much you spend.
What the heck. Did anyone figure out why they would remove such a useful feature? I might have to buy a Dodge Ram now just for the pedals (which are recalled btw for the brake pedal falling off if you use it)
‘19 2500 is still the old body style though. Why they eliminated them on the T1 is beyond me. I’d have to assume it was some kind of cost cut.
The adjustable pedals was the only way I could talk my wife into the 16 I have now. No way she goes for a 19 without them. She puts the pedals all the way up then she can sit back from the steering wheel. I will have to fashion up some wood blocks for her feet?
I also found the pedals particularly useful when I wear my heavy hunting boots, just push the pedals back an inch or two. It is like a heated steering wheel, you never knew it was a feature you couldn't live without until you have it.
The steering wheel does telescope now, not just tilt.  It's not the same and won't help your boots but might help your wife.
The tilt AND telescoping steering wheel has been an option.
Or just buy her an assortment of Stilettos :D kind of a win-win...
Edited by SS502
  • Haha 2
My thinking is they got rid of adjustable pedals to save weight.  Same with automatic steering wheel adjustment.
The adjustable pedals in my K2 are not only a convenience, but an added safety feature of sorts.
Both my wife and I are under 6' tall and about 4" difference in height.
So, the 1 & 2 driver memory settings come in handy when we are able to custom tailor the pedal position to our liking.
The option to move the pedals toward the driver increases the distance from torso to steering wheel, which in turn is a safer driving experience.
GM axed this option for T1. Also, no turn signal indicators in the side mirrors which I have liked going back to GMT 800
They probably needed room for the auto stop/start disable button, so the adjustable pedal button got axed
Gotta pay for the autonomous and electric cars that are coming. Thus we get the cheap interior and loose many features that were available and standard  on the previous generation truck. Can’t believe how dumb GM thinks it’s customers are!
Get used to the idea of having your future Silverado or Sierra powered by an electric motor....    :loser:
Edited by Sierra Dan
At least in my life time I don't have to worry about them.  Just like what has been in the news. The cold weather really took a toll on them.  So until they can over come that, they will not be main stream for a while.  Not everyone has a heated garage to put one in.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
