The Inevitable Comparison: GM 6.6 vs. Ford 7.3
1 minute ago, 07HD said:
But the 7.3  is  still old school technology ?
IMHO.
  • Replies 120
Top Posters In This Topic
Posted Images
1 hour ago, Carolina said:
Care to explain how reving a engine  to a point of more torque and horsepower is gonna make it pull worse? The truck has more capability to accelerate at 5000 rpms because it has more torque than at 3500 and will be harder to slow down because it’s near it’s peak horsepower and will have the least chance of slowing down at its max horsepower. That’s why you punch the bitch to keep speed
I was on your side of Keeping the revs up and just above the torque peaks etc. Read my posts about when towing staying above 4g is better. Maybe i miss posted or miss quoted?
10-4 . I missed the early post and took it wrong but either way it’s some schooling for the youngins.
8 hours ago, Carolina said:
Your concern of the gas engine lasting . The wear is similar on a diesel at those rpms.Also downshifting gives it the opportunity to have more horsepower to keep it from slowing down. Nobody is trying accelerate up hills there trying to maintain speed . If you don’t think diesels have to rev on hills you must have never towed with one with a big load up a hard grade . I’ve watched my duramax loose speed many times and had to floor it only to watch it fall
In my pulling years I would gear my gas or diesel to pull its load at the lowest RPM possible to stay around 60 MPH. Usually gas would be 3K RPM in direct drive not over drive. Diesel 18-2K RPMs for obvious reasons. There would be times obviously I would drop a gear to pull up hill. I wouldn’t want to live at that RPM. None of my Rigs were stock. Gas had headers, tunes some had cams. Diesels had banks kits. My rigs were registered for 30K combo. Usually pulling 24K combo. I had business demos, training coast to coast. In the mid 2000s our business got to the point I couldn’t take the time to pull my own stuff anymore. I hired it out. I missed it though. I did it 30 years I know what it takes.
I guess your experience is too “dated” . I don’t care if you were the test driver for GM . The facts are facts
If you were within your weigh limit and lost speed dropping a gear you probably had the wrong gear. I never lost speed dropping a gear. My nephew continues to deliver equipment at times. The advancement in technology with more horsepower, TQ and gears has made it possible to haul the same loads at lower overall RPMs. Still hauling 24K combo.
The moral of this, albeit off-course discussion, is that if towing near max capacity, keep the new 6.6 in the 3500-4500 RPM range to maximize both peak HP and peak TQ for extended pulling up steep grades. Generally unnecessary on flat ground, but there when you need it. Same with any gasoline engine under max load. Finding the sweet spot between peak HP RPM and peak TQ RPM is where it will shine.
It looks like the L8T 6.6L will soon be available in the 3500/4500 LCF medium duty trucks.  No word yet on the Silverado 4500/5500/6500 yet.
There are some people making a lot of hp with the 7.3 Ford.  Those Ford people are claiming the 7.3 is loosely based on the old 351 Windsor motor.
Looks to me like it's based on the Chevy LS more than anything!  Don't see any Windsor in it, but the Ford 7.3L is built in the Windsor engine plant.  Maybe that confused someone.
No joke it’s 6.0 clone with more cubes
I totally agree on it looking like an LS clone but larger.  I’m just sayin the Ford people aren’t gonna admit it.  Even the square intake port shapes are very similar, the port in the Ford though extends out from the head a bit.
well,  on another note.  had 3 diesels, then bought the 6.6 gas. dont miss putting the bra on, dont miss plugging it in. dont miss def fluid. dont miss 30 to 40 cents a gallon more for fuel. dont miss the warm up times in cold weather. kind of like the gas again. and im not a ford guy. drive what you like. i am. lol.  by the way,, the chevy hd front end is the best looking front end out there in my opinion. just saying. lol.....    oh,,, and dont miss regens
I agree if I didn't have to tow anything I would switch back to a gas.
    DM22
    DM22
  • Who's Online   7 Members, 0 Anonymous, 1,689 Guests (See full list)
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
