Doesn’t make sense to remove them, if there is additional cooling needed, I would think they could program them to open if certain parameters are reached. I agree with @newdude that you’re probably better off without them. Not sure on a 2019 but on the K2 they really make mounting a light bar behind the grill a PITA.
Should you say but it does enough to the point i went looking the day after i picked up because warm up time (time it took to have heat) was noticably longer than my17 ltz 6.2.  Made it through 2 winters with zero return to dealer issues with ltz, trans had me worried for first few thousand but did get better and even was “normal” after 10k and i work afternoons so get out 10pm to 1am no freeze up
got best 28mpg, total lifetime never reset since off the lot 18080 miles 16.8 and on trips got a easy 22-24mpg, all summer pull 7x14 landscape trailer with 1100lb zero turn mower
Just find it funny/Contradicting eco motor cylinder deactivation for fuel economy and yet remove the shutters
I assume you’re replying to someone else? I only said it didn’t make sense to remove them. There is obviously no way for them to break if ya don’t have them. I don’t understand why they felt compelled to remove them if additional cooing is needed....just program to open when needed??
I’m not an engineer but presumably when the engine is started cold and the t-stat is closed, is anything even flowing through the rad at that point? In other words, how would the shutters help warm it up any faster?
I would imagine they didn’t fit them because even when they are open it does restrict airflow. Probably not a huge amount but if you’re towing something heavy in the summer, maybe every little bit helps??
Also, did the EPA fuel economy numbers go up at all with the introduction of them in 2017?
Was responding to newdude not mark
seems counter productive removing them is all i believe and should be shown somewhere as to them being removed with X option added
mabey at stand still no difference in warm up but driving down the road at 0 degrees has to pass less cold air over the motor with shutters closed i would think and noticed my usual spot the auto heat kicked on was extended a few mile further i noticed first night leaving work
when i remote start standing with my ear on the grill area i hear a quick click mabey someone with shutters on a 19 can look and listen and see it that is the motor closing the shutters
will speak with local dealer tommorow and poke around looking to see what is there and not when warmer
Ok.
Flipped through the catalog with some VINs.
NHT with both the 5.3 and 6.2 do NOT come with active grille shutters.  The grille shutter frame is present, and that is it.  No shutters.
NHT cooling requirements eliminate the shutters and their actuation.  If you were to attempt to install, the wiring, etc. would not be present.
If you really, really, really have to have them, trade the truck?
EDIT:
Adding the shutter RPO codes.  NHT trucks won't have either show up in their build.  Also, WT/Custom/Custom TB with the old engines/6 speed don't have shutters either.
VTI - Single Shutter.  5.3 L84 and 6.2 L87.
WMI - Dual Shutter.  2.7T4 only.
Edited by newdude
ADDED SHUTTER CODES
Thanks for the info think gm would have put that info under the rpo code nht so the consumer would know what is being removed not just added.
Sad part is there enhanced cooling probably consists of just removing the shutters not a larger capacity radiator
Now I understand what my truck takes so long to warm up and all times is working under low temperatures, compare to my previous 14 with the same 5.3L.
The shutters were only started with the 17+ model years.
I was working on a 2018 Colorado ZR2 Duramax the other day and had to replace most of the front end because of a deer hit. I had to get a new shutter assembly for it and when it showed up there were no shutters in it. I called the dealer and he said that is the way they are spec'd. I had 2 block off plates for the lower shutters and nothing installed in the top.  Ask the engineering dept. , right?
Be nice to have on my 17 HD as it would stop the truck from cooling itself off at idle when it's cold outside.  Switching to e fans would accomplish that too but the good old e78 ecm doesn't have the mental capacity to accomplish electric fan control on the trucks.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,122 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
