Hey guys, just purchased my first "new" truck last week for my 22nd birthday. I've already caught the bug for upgrades. I am picking up a factory 6.2 exhaust on Sunday. As far as bolting up to the factory y-pipe, will I have any issues? I wouldn't think so since both are factory exhausts and for same truck model, but it's better to ask now than have the stock exhaust already off and run into problems. I know I should net a little extra power, but I am also chopping off the flapper valve and replacing the stock muffler with a 3.5" Borla XR-1 and leaving the resonator, for now. Future plans will be 1 7/8 headers and y pipe. Anybody have a similar setup with the 5.3's? As far as swapping over to the 3.5" exhaust? I know a lot of aftermarket exhausts are 3.5" to 4" but are pretty pricey. I think for spending $100 on the factory exhaust, $200 for muffler, muffler/valve chopped off, it should be a decent upgrade
I believe they are different.  I thought the exhaust diameter was larger on the 6.2., and the ball connector wouldn't fit.
you are going to want a replacement Ball Clamp, your most likely going to have cut the one that is on the truck off.
I know the diameter is different, I just wasn't sure on the connection if they were different to mat up to the existing y-pipe. I haven't looked but I figured it wouldn't be an issue. I will check it out though!
Yes they are different.
The converter y-pipe and the exhaust are 6.2 only, and the 5.3 stuff is 5.3 only for the factory equipment.  The ball socket on the back of the 6.2 converter is larger to accommodate the larger piping, and the clamp is larger as well.  GM uses a ball/socket joining method between the cat and the exhaust, with a somewhat spherical clamp.
You'd have to get the cat y-pipe as well to use the factory 6.2 exhaust.
Edited by newdude
If you are getting headers just add the 6.2 exhaust then so you can have it bolt right up.
I am getting long tubes and y pipe eventually, for the time being I was going to throw on the 6.2 exhaust with aftermarket muffler for mean time. I didn't realize the ball joint. So I will hold onto the exhaust and wait until I upgrade to y pipe and headers!
...or just have an exhaust shop modify the y-pipe (since your getting rid of that eventually anyway) to fit the 6.2 catback.  Shouldn't take much.
True! I'll see what they can do. I just don't want to spend too much on it since it wont be long before I remove the stock header and y pipe! Thanks for the tips
The 2 cat backs are not compatible!
The 6.2 and 5.3 exhaust are the same after the flapper pretty much anyways.  The 6.2 exhaust goes down to 2.75" for the resonator and tail pipe, there is no reason to swap your 5.3 exhaust for a 6.2, the only thing that is bigger is the muffler and intermediate pipe, you're wasting your time and money.  Just slap a muffler on your current exhaust and delete the flapper at the same time.
Well, update. Picked up the 6.2 exhaust over the weekend. Going to go ahead and pull the trigger on longtubes and y pipe from Speed Engineering today. Going to get everything installed and then have a 3.5" Sportsman Borla XR1 installed. Going to leave resonator on there to keep it a little more quiet. Should have everything installed and tuned within a month or so!
  • 4 years later...
On 3/24/2019 at 6:24 PM, qwank said:
I have a picture of both for reference
What is the diameter size of that socket for the 5.3l?
What size male ball goes into the female socket on the 5.3l?
The long tube headers kit I got doesn't have the connector pipe from the long tube headers  to this expansion pipe.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
