Bilstein 5100 on a 2014 ltz
So I found a set of bilstein 5100’s for all four corners on amazon for $356. I was looking through the add and came across a Q&A section. There were a few posts saying that if the truck has a 2”, 2.5” or a 3” level the only way the fronts will fit is if they’re on the lowest setting. Does anyone know if this is a fact? I’ve got a 14 Ltz Z71 with the 2” rough country level and I really want to go with the bilstein 5100’s on the setting one up from the lowest.
Just add the 5100’s without adding any height, you don’t have to put leveling settings on them.
I and thousands of other had 5100’s without the leveling clip installed as front shock strut replacement.
Sent from above
Sent from above
But I want a little more height then what the leveling kit is giving me. I would rather just go with the bilsteins and put them on the setting one up from stock height with my leveling kit I already have. I want about another half inch height up front(2.5”) and the bilsteins don’t go that high.
Couldn’t help you there, I hated having block leveling on my truck, it rode really rough and that was with new 5100’s front and back. The higher you go the worse the angles are and rides rougher than stock especially with E rated tires on. I do not recommend you going at 2.5” without new UCA’s and then possibly a diff drop. There are a couple kits out there that’ll give you a level Diff drop with uca’s for low budget minded people.
Sent from above
I had a 2015 that I put the bilstein 5100 all the way around in with the ride height adjustable in the front. I had the fronts on the highest setting with a .5" spacer and then changed out the stock back block (1") out with a 2" block to keep about 1/2-3/4" rake in it. I was very pleased with the ride quality. It still rode better than stock, smoothe as butter
Sent from my SM-G955U using Tapatalk
I’ve got about 1.5” of rake with my 2” level kit installed. I want to take about .5-.75” out of that 1.5” of rake. Since I am in the market for new suspension in all four corners, I figured I could go with The bilstein 5100’s and go up one notch from stock up front to give me what I want with my 2” kit installed. But I have read on amazon reviews that if you have any sort of leveling kit already installed, the only notch the bilsteins can be set on is stock and was hoping to see if that was true or not. My goal is to just buy the bilsteins and get the height I’m looking for with my leveling kit and not buying another leveling kit and suspension.
I find that interesting considering you’re the first to ever say doing a level with blocks actually gave you a better ride than stock considering your angles change once you add a leveling kit and more so with Bilsteins and we’re all doing it just to add larger tires which then with E rated tires immediately stiffens the ride so back to your “smooth as butter” that’s a far stones throw but kudos to you for achieving something never been done before. Be safe
Sent from above
Sent from above
Believe me, I was skeptical as well, especially with the spacer on the front, but the shop that did it is an off-road shop that deals with stuff like it all the time, guy pretty much guaranteed me it wouldn't affect it and that the bilsteins would still have plenty of travel both ways. I did it partly because I like the level look on trucks but also to put 33x12.5s on there on my stock wheels. I was thoroughly impressed with it. I've since traded it in for a 2500hd and put a cognito level kit on the front with uca's and bilsteins all around on it, it's also a night and day difference. South east Houston is where I'm at and there's good roads and rough roads I travel on the way to work and like I said, I was very impressed with both trucks. That being said, to each their own and I realize people have different experiences, just thought I'd share mine.
Oh ok, I read over the part about you already having a leveling kit. I'm not sure how that would work as I just used the bilsteins for my level. The thought that goes through my head in your situation would be that you could just leave it on the stock setting since you're already 2 inches up. If I remember correctly the bilsteins travel is made for 0-2" of lift so you should be fine, maybe add some spacers on them for the extra .5"-.75". I had a .5" spacer and the truck rode great, never once hit the bump stops and I drive the occasional rough road
That’s just it, I don’t want to add another spacer. I just want to put the setting on the bilsteins one up from the lowest level. But on amazon in the comments part, it says the bilsteins can’t be used with a 2” leveling kit. And I don’t understand why that’d be.
Where are you located? I'd call a local off road shop that does lifts, they should be able to say for sure, because those Amazon reviews look conflicting and you never know if they know what they're talking about
A7#-Effzzz7zzz'zz6ffsx, a ☆7[emoji830]︎•=_¤
Sent from my SM-G950U using Tapatalk
3 minutes ago, AppleTreeShadow said:
A7#-Effzzz7zzz'zz6ffsx, a ☆7emoji830.png︎•=_¤
Remember to get a front end alignment if installing bilsteins on anything other than stock setting. I installed mine at 3rd from bottom for 1.75” of front lift. My toe was way out in the front. Seems to drive fine but would have chewed the front tires.
Got it an alignment and it’s strait as factory.
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
