I’ve noticed in my ‘19 Trail Boss LT that my gearshift is loose. When I’m in drive there is a lot of play in the shifter. It seems to move up and down about a 1/4”. Anyone else notice this?
I’ve noticed in my ‘19 Trail Boss LT that my gearshift handle is loose. When I’m in drive there is a lot of play in the shifter. It seems to move up and down about a 1/4”. When in park there’s minimal play in it. Anyone else have a similar experience?
I had the dealer look at it, and they said it was "normal" as all of the other 19's on the lot had the same free play when in the drive position.
I am now trying to ignore the thing bouncing when going down the road.
That is the only issue I have had with the truck, so I am lucky I guess!
Thanks for the reply. It does bounce for sure. Seems like there should be a way to tighten the shifter up? Ugh!!
This has come up in other threads recently.  Mine definitely does not have this kind of play in it... very solid.  Others chimed in similarly.
So I assume it's not supposed to.
I have driven 3 2019 Silverados in 2 days. I checked each one. Once it is in drive, I can jiggle the shift lever up And down maybe 1/2 inch either way. It doesn't seem loose when running through gears though. If anything it feels stiffer than my 16 was.
Yes! This is what I was referring to. It's very tight shifting out of park into drive, but then I can wiggle it up and down like you mentioned. My wife has an '18 Tahoe and it the same with hers. I guess I'm worried for nothing as this seems to be "normal". Thanks for the reply!
I am ashamed I am always looking for defects with new vehicles OCD I did not pick this one up until you mentioned it,yes when trans is in drive I have about a little over 1/4 inch play up and down,but like mentioned very tight  selecting  park to drive reverse,etc. Custom Trailboss 1600 miles.
Keith
Keith
So I am sure then you already checked to see if your bed was perfectly aligned with your cab?
OCD x2
No problems
OCD x2
Straight
OCD x2
Damn you.  Now I gotta check mine and it’s raining.  Dammit.  Lol
  • Haha 1
:D:D I did actually go out in the rain to check when he mentioned it.
  • Haha 1
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
