Also will have a sicker in the door jamb that will just tell you what plant the truck was built at.
There is a bulletin #18-na-254 info on oil residue found on oil cooler lines during PDI but not sure if it's related. I looked at www.repairprocedures.com but don't see any other bulletins about oil cooler lines.
Sent from my Pixel 2 using Tapatalk
1 minute ago, ShamrockShooter said:
One of the stickers on the driver door jam has a date on it. Also your Vin starts with 1 it's a US truck 3 Hecho en Mexico
Mine is a US truck then.  Not sure on production date since it'll be in the shop for the next few weeks but it was on the lot in Western NY in December.
Well you can also get a sense by the VIN number. The last six digits is a sequential build number. Mine is 107xxx so it was the 7,xxx truck built on 8/18. If you look at your Chevy app on your phone what is the first 3 of the last 6 digits? I'm also a western NY truck.
143XXX
Driver side open up door look on the inside of drivers door mine has a yellow sticker FT Wayne then look where the door meets the body lower half the built date mine is Dec12th Purchased in South Jersey.I have not had this problem or any ,hope it stays that way on my CTB .I do only have 2100 miles on it
Keith
Edited by K455
1 minute ago, K455 said:
Driver side open up door look on the inside of drivers door mine has a sticker FT Wayne then look where the door meets the body lower half the built date mine is Dec12th .I have not had this problem or any ,hope it stays that way on my CTB .I do only have 2100 miles on it
Keith
If it was me I'd seriously consider having it looked at.  Mine had 4,600 on when it went.  Literally drove 200ft. with the leak and lost a lot of oil, still waiting to hear from dealer on engine damage.  Would blow an engine quick on a highway I'd guess.
A bad crimp can be caught at the dealer,without a bulletin ?
I feel for you,I would be highly agitated and demand a new crated engine at least!!!
They replaced the oil cooler lines, refilled oil, changed filter on mine. I had expressed my concern over a possible fatal issue. I allowed the Service Manager to take my truck home overnight to put some miles on it (~90miles). There was no unusual sounds after so I took it home. I have put another 500 miles on it without any issue. They said about 2 quarts of oil was left and they allowed me to keep the oil filter, which I will cut open (reality is that probably didn't collect any oil anyway as it all went on the ground and didn't recirculate). I pulled a small sample (4 ounces)of oil out when I got home and I do not see any flakes, particles, or shiny stuff. Pretty crazy that I had  almost 8,000miles on it when it went. I figured something like this would happen early on, or during the winter at a -10degree start.
i will probably take another oil sample this weekend and maybe switch out the oil filter again to check that one. I had my truck shut off pretty quick, so that may be why I escaped major damage. With another 50k miles to go on the powertrain warranty I think any issue will show up before then..
My Truck was built in Ft. Wayne 140xxx serial number. I picked it up just after Thanksgiving 2018.
Edited by sicilit
Geez.... I'm both glad I read this Thread and I wish I didn't.  I'm gonna worry about this every time I take a trip (going to Pahrump early next week) and especially off road.  Especially off road.
Any way, thanks for this Thread :thumbs:.  I think :sigh:.
I'm going to check my lines for any sign of defect/oil seepage. And keep checking them, although it may just go without any other sign.
I think if mine does go I would rather just let it runs till engine seizes. Start it once more just to be sure, then call OnStar. Think I would rather have a new motor than worry about damage from running on no oil.
On star would record that you did that, probably not a great idea.
Yeah, you can't get away with stuff like that these days.. Unless it blows while it's sitting in your driveway idling while you're inside getting ready to leave...
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
