On ‎4‎/‎27‎/‎2019 at 9:50 PM, relevante said:
Do they tend to leak at all if you’re looking closely before or do they often just blow without warning? Is one end or the other consistently the problem? Is there any better aftermarket replacement available?
The three old body trucks had no rupture/total failure.  They were seeping/leaking at the crimps however.
The only way this becomes a safety issue and recall is if everyone of the affected owners files a claim to NHTSA. It needed over 200 complaints on the k2 vacuum pump brake failure I had on my 16 before they sent a letter to gm to investigate.
This could be as simple as one bad batch of hoses that was used for a few weeks. GM will figure out real quick if it is cheaper to replace 100,000 hoses or a couple thousand engines.
If the owner shuts off the engine quick enough, this could be a simple as replacing the line and filling it up with oil.
I looked at my lines yesterday and I don't see any signs of oil seepage at the crimps. Mine is August 2018 build ft. Wayne
Sent from my Pixel 2 using Tapatalk
Truck just got towed in. Chevy roadside wanted to charge me for the miles outside the 25 mile radius for towing to get the brand new truck back to dealer where I bought it Friday night. Already getting a bad feeling from Chevy on this.
Will update once dealer calls me back. I will be pushing for an extended warranty on the engine
Had to stop by our local dealership for something other then this and then went back and talked a good friend of mine for years who is in charge of the mechanics of the shop and ask him about this and he told me he hasn't seen any blown engine oil cooler lines come through his shop since these trucks have been sold, he went and checked the main GM data base and then some other one that checks other dealerships for this problem and seen nothing.
Mine's an 08/21/2018 build.  Hope ours is okay!
Dealer is telling me the crimp was just loose and they will put a new part on. They say I have absolutely nothing to worry about since they say I was only 1.5 quarts low in oil. Would that make sense with the check engine light being on?
Not sure. In my case there was virtually no oil left; so it sounds like you were able to get the truck off quicker than I did.
Assuming they aren’t lying, I wouldn’t be too worried about 1.5 low in an 8 quart sump.
I literally just picked up a 2019 Trail Boss last night. My first American car, now I am super freaked out.
It can happen to any vehicle. Most people don't realize that Toyota has had issues with external oil lines failing for several years now. Lots of Camry's have had engine failures because of it. Yet people buy Toyotas and live with a false sense of security. I wouldn't worry about it.
Edited by HondaHawkGT
  • Thanks 1
For anybody in this thread that's had an oil line fail, please help out the community by sharing your information here:
It could help identify any pattern to the failures.
I noticed it when wife moved truck and driveway had huge oil puddle.
Why don’t u just list it on this thread the one everyone is reading
Because then you'd have to sort through 30 pages of conversational comments to find each individual post with their truck's info. You can see how well that worked in the truck vibration thread in the K2xx section. Having a separate thread keeps it organized and actually useful.
  • Like 3
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
