So several of you have added the 1.5" motofab leveling kit. Some even a 2" on the 2019+ fb group. I am wondering how is your suspension responding and how many miles have you been running with the leveling spacer? Recently I started to notice a trend on the trailboss owners opting for the 1" instead to stay on a safer side. I have the 1.5" sitting in my garage and now am having second doubts on installing it or ordering a 1". I really want to just bite the bullet and go with the 1.5". My old 17 z71 ltz had a 2.5" and developed a steering noise after a couple of miles. So overall how is your truck doing; any noises or cv axle leaks?
1.5" motofab  on my Trail Boss with about 750 miles........no unusual noises or problems to report.
Thanks for the quick reply! Hopefully more people report their stats too and this can serve others like me as an assurance!
1 1/2 motofab on mine. 5k miles and smooth as can be! No problems at all. Zero regrets!
19 hours ago, destrada127 said:
5k miles here too on my AT4 and I've had no issues whatsoever6678ceb6aa5bbd0592e73b1e71ad0f4a.jpg
Sent from my SM-G975U1 using Tapatalk
Wooow awesome guys! Trucks are looking great
1 hour ago, Chred said:
Around 1500 miles since installing the 1.5” Motofab.  No issues yet
What Re the wheels and tires you are running, looks great
Thanks! They are the Fuel Assault rims with Toyo Open Country AT2 305/55/20
Can you post the link to the kit for the 2019 silverado? are you just doing the front? appreciate it and good luck!
Www.motofablifts.com
Did you get it alligned after the motofab lift? If not have you noticed your tires wearing unevenly?
You should always align after any suspension work, I did after my 1.5" install and it was off by looking at the before and after alignment sheet, and it drove better after the alignment.
Absolutely need an alignment. It will drive fine without it, but you will get uneven tire wear for sure. I didn't get mine in for the alignment for a couple hundred miles and that didn't cause any problems but I wouldn't wait too long!
Heck mine drives better now with a fresh alignment with the leveling kit than it did brand new. Now i'm not saying the leveling kit made my truck better, i'm just skeptical to how well my truck was actually aligned from the factory. I have the 1" motofab kit on mine. I did get an esc trouble fault running through the mud at my property the other day but once i turned the truck off it went away. I haven't been able to replicate the issue again.
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
    • It get absolutely nothing. No chimes, no dash lights, it won’t crank. It’s completely dead outside of the obd2 port which is throwing no codes. I’m wondering outside of a rusty ground somewhere if it could be a connection on one of the fuse blocks? I would not be surprised if water could get under the main panel under the hood on the drivers side.
