Steering Wheel Kicks Back Hard
Ge0rge
Today I went to pull out and turned the wheel about 1/4 turn and it kicked back and almost broke my wrist. It kept doing it, stabilitrak said to be serviced, traction control turned off. Then I shut the truck off and it would not do anything, no sounds, no start. I jumped it and it worked. I shut off and had to jump it each time. Did this three times.after the third time it started easier with a jump and then would not reproduce the issue, though it did it between each jump start otherwise. I seen the other thread on this but I am thinking it's a battery that needs replaced. The battery voltage on gauge is about 15 to 16 by the looks of it and will go down to 11-ish sometimes I have noticed. Anyone else remedy this issue by replacing the battery?
What does the battery show with the truck off and the key turned forward to run?
Sent from my SM-G955U using Tapatalk
5 minutes ago, Ge0rge said:
Well my son and I noticed the negative terminal was a bit loose so we tightened. I went for a 5 minute ride and no issues.
Prob it. Easy and cheap!
Still see the odd voltages on the meter, I am going to pick up a multimeter tomorrow. Thanks for everyone's help, I love this forum. My sub amp tends to wear the battery down. If the truck is parked and I have the stereo on but truck off I get tops of 15 min before battery saver kicks in and shuts it all down. I want to find a rather large battery.
Best thing to change is the habit of using the stereo with the engine shut off.
Lower that it probably should.
As long as it's in the range of the 12-16v or whatever it is, it should start. Glad tightening the negative worked for you. My question, just for future reference, stemmed from when I had a bad cell in my battery on my 15. Truck would run fine after a jump, but every time I shut it off it wouldn't start up again, it would only start with someone jumping me. Noticed the volt meter was barely above 9 with the truck off and the key on. Not enough to start it. Took it to the dealer and ended up being a bad cell
When I first noticed it I shut it off and on a few times and repeated the issue. Then I shut it off and nothing worked, zero power. Then I jumped it with a battery pack charger, and then it worked until I shut it off, though repeating the problem. After the third or so jump start it worked as normal with no issue. I then found the loose neg clamp and tightened it. I am not certain it was the issue but it did not do it on my test drive. We'll see tomorrow how it goes. I will tighten that wire under the dash by the speaker if needed next.
1500 miles out of the 36000 mile warranty, go figure.
I am guessing the charge in the battery or current it could supply while loose, caused the drop in voltage and the steering wheel kickback. Is that why?
