On 2/16/2020 at 8:37 PM, jflan23 said:
I looked at their website earlier they do have one for the new Sierra’s
Has anyone installed one of these on a Sierra?  Pics? I bought an "open box" one on Amazon for $48, but haven't installed it yet.
One of the reviews I read was a complaint about wind noise. Anyone on here with that problem?
  • 4 months later...
Can’t thank you enough on the wiring pics! Looks sharp and has minimal noise on my 2020 Trail Boss.
Craig N. your truck looks awesome!  Where did you get your tow hook shackle conversion kit? I like it!
Thank you! I needed to make it different than the others out on the road. Rough country makes both the brackets and the recovery shackles. Let me know if you have any problems tracking them down. I had to do some digging for the shackles.
Thanks!
Looks like the textered matte black finish on the one above. Do they offer the smoke clear/gloss black in one of these?
Yah i would like one in gloss as well to match the grill and bumper. Looks like they make colour match so yes, gloss black.
  • 3 months later...
Hey everyone, was hoping someone could help me with this install. First, I can't pull out the wiring harness behind the driver side headlight. I got the red pull tab to come out, but can't pull the harness out. Any tips to get it off or is my only option to remove the grill to better access the headlight? My second thought was to use a piggyback connector on the fog lamp fuse, #49. Im clueless when it comes to electrical, so I'm not sure if that would even work? Are there any other ideas to wire it more simply? Thanks
I removed the headlight bulb and tapped into that harness. It was much easier than trying to reach the entire harness at the bottom of the headlight. The posi lock connectors and exisiting wiring can tuck in behind the bulb and then everything gets covered by the large rubber flapper.
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 550 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
