Testing the water to see if anyone is interested in purchasing front brake upgrade for 2014-2018 silverado 1/2 ton trucks or Suv. i have a source to acquire like new loaded calipers and the new rotors to make it happen and have the proper spacing requirements to make them work on your truck. I have already done this mod to my 2014 silverado and can tell you it is a very noticeable upgrade from what the oem had to offer in those years as well as a more appealing look all together. Both front calipers loaded with pads and hardware and front rotors 500.00 plus shipping to the lower 48 states. This is a drop in the bucket compared to the thousands it cost to get the Brembo upgrade through GM. message me if your interestedIMG_3009.thumb.JPG.69a69a511f6efc69c2e19ac8da7d8fc3.JPG
Edited by ModJunky
grammer
These are four piston calipers i will try to give as many pics and details as i can IMG_3010.thumb.JPG.31ee8dbc204191d5b306726e999be890.JPG
Need more details. What is the rotor size vs stock? And front only what about rear, just curious.
Rotor diameter is very close to the stock size the big upgrade here is the caliper itself, this is a four piston setup versus the two piston. if you need exact measurements i can get them for you but it fits the same lug pattern and with the proper spacers you just have to center the caliper on the rotor since they no longer float like the original
The rear caliper does not look to have changed i have yet to source in the rear in since the pics i received from my source looked no different from my current model truck
If you don't mind me asking what city of Michigan are you located? I am the waterford area but all over oakland county.
Are you saying there is a front wheel spacer needed to clear the caliper to the rim? If so how big as I have 24x9" wheels and lowered 3/5" so spacer may be limited.
I’m in waterford and no spacer for me I have 22in factory rims
I had to space the caliper out from the spindle to center the caliper on the rotor no spacer needed to space the wheel out
I'm interested but first I will research it a little more and see that I can get. And powder coat options.
The whole point of a big brake kit is to stop better and fill the wheel up.
If you still running the stock size rotor then what is the point ?
Yes and no. 4 piston calipers are more then twice the clamping force. And the caliper is a better material. Also the rotor is better if it is larger for heat distribution and surface space but it is also more mass to move. Pros and cons of everything. Also I would look more at brake feel under lower line pressure and fade under heavy use.
GM says 22 and bigger wheel need performance brake kit. And my 24" and power level could use wilwood huge brake kit.
If you read up on this drilled is more of a looks then performance. Big race kits are slotted or nothing. Even wilwood and bear have wrote articles on this.
I want the wilwood but if I switch to smaller wheels I would rather have this, then there is the rear issue. Can't fit 15" with slicks out back with even stock brakes. So 1320 makes a rotor and single or dual caliper kit. Some say down grade but it is more surface and clamping force.
What kind of spacers are required or is a direct bolt on?
He said the spacers are for the caliper mounting bolts. And this is reasonable on a dual side of rotor pistons as the alignment is key to even clamping and wear.
Yea I can read. I meant is it a few washers or machined out, a few washers i'd consider bolt on.
    • My take: I don't think seeing up to 200k on the odometer of any of these engines/trucks (2014-to present) is surprising. (Excluding the known DEFECTS, specifically, the 6.2 main/connecting rod bearing issues, the defective lifters, alternatively parts that a recall was issued for - I think there were three.)   250K is my line in the sand, anything over that is 'surprising', but not limited to the engine making it that far but including the truck surrounding it too. (We've talked about this in other posts, why I think the engine isn't the deciding factor for ultimate mileage.)
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
