1 minute ago, MaverickZ71 said:
As for myself, in my never-ending search for the perfect oil (that is, oil that is easily obtainable to the common man at the usual places that automotive parts and fluids) to combat AFM problems, I've migrated to Shell Gas Truck motor oil.
I too was thinking on switching to the Shell gas truck oil once my 2 "free" oil changes get used up (I'll have the dealer to them every 4k).
I read an analysis on filters, and was considering switching to Motorcraft filters (such blasphemy!) due to somewhat better internal structure in some aspects.  Wix aren't available locally, but the local AZ does stock both AC Delco and MC filters.
  • Replies 53
On 6/12/2019 at 3:50 PM, JimCost2014 said:
I have been using the new AC Delco synthetic at the dealership, seems to be a good oil, either made by Mobil, or Phillips 66.
My old Gen IV all aluminum LS is pretty quiet motor but was beginning to make some noise on start up once a few thousand miles had passed since the oil change.  Was using Mobil 1 full synthetic, regular weight oil, nothing fancy.  Viscosity numbers are a little thinner than ACDelco's new oil and Shell's Rotella Gas Truck.
The ACDelco oil I'm running was made by Phillips 66 Lubricants and has been great so far, resulting in slightly higher oil pressures across the board and has improved the truck's fuel efficiency.
The only engine oils whose specs show better viscosity numbers are the Group IV based oils, like Amsoil and Red Line.  I was a lifelong M1 guy, been using it since the 1980s but they changed from Group IV to Group III about ten years ago and was a little thin for my engine's liking.
10-9147/88865743 for 5-Quart Jugs - BUT Those Gen V DI motors take 0W20, so get that!
4 hours ago, MaverickZ71 said:
Time for ol' Cowpie to chime in on here to remind us all that the additive pack in the oil is as important as the base oil, and that while the base oil may last a long, long time, the ingredients in the additive pack do not necessarily last that long.
As for myself, in my never-ending search for the perfect oil (that is, oil that is easily obtainable to the common man at the usual places that automotive parts and fluids) to combat AFM problems, I've migrated to Shell Gas Truck motor oil.  It's a full synthetic, is Dexos-certified, is for any mileage, it stands up to severe heat/cold and towing/hauling, and it contains their diesel oil additive pack specially modified for gas engines.  Shell Gas Truck oil is rated higher than Shell's own Pennzoil Platinum and Quaker State Ultimate Durability, which are both rated higher than Mobil1).  I get my Shell Gas Truck oil at WalMart (5 quart jugs) or Autozone (jugs or quarts) and my Wix oil filters (same as NAPA Gold or Platinum) from O'Reilly Auto Parts, since my cache of AC Delco non-E-core oil filters ran out.
I swapped over to Rotella Gas Truck 5w-30 a couple of weeks back and immediately went on a 600 mile trip pulling my toy hauler to the beach.  So far I like it over the 0w-20 I was using.  Engine was quieter and oil temps were lower than before in identical conditions.
I was one of those whatever is on sale I use type of guys but I think I'll stick with the Rotella for now.
I’m not up on the AC Delco filters...did their construction change (for the worse)?
I know from my brief blue oval days, use of non-MC filters was a sure fire way to bring about valvetrain noise, and cause the old 7.3 Powerstrokes to have increasing cranking times before starting.
Ok, just did a 4K mile oil change, Mobil1 0W20 Annual Full Synthetic is always black when I change it at 4K miles, this is Amsoil 0W20 Signature Series at 4K miles, looks like it’s only got 2K miles on it, proof is in the oil change, EXTREMELY IMPRESSIVE!
Looks like I’m getting a bit low
Sent from above
Just this oil change I've been pulling the stick for a look every 500 miles to have a color look. 4K a few days ago and the exact same result with the Red Line you got with the AMSOIL. Ditto on both Mobil 1 and QSUD. Black as tar by 4K...by 3K actually. Thanks for posting that!
That should answer the 'color' question. As both of these oils are PAO/Ester and esters have excellent solvency you now know that the color is NOT suspended solids. So back to my original question. Why do you change oil?
I’m adding information to the OP’s question, Grumpy you should start your questions as to why change engine oil on your own Topic but for right now I’m answering the OP’s question in order to help decision on choosing the right oil that does not break down as quickly as other well known over the counter oils. We all know you love to over analyze everything you put your interest in but OP started a topic “What kind of oil to use?”
Sent from above
5b08b769836fe11451dabc767e68ab2c.jpg6K miles on my Toyota Camry since last oil change. Oil just started to show color. Whatever that means.
Darker the oil the quicker break down and more soot accumulated from the oil. Apparently, it gets especially bad in DI motors
Sent from above
Sent from above
Yes. It makes a good argument for more frequent oil changes.
Personally, I believe changing your motor oil at what’s considered as safe intervals is the way to go, unfortunately, our DI motors help escalate the breakdown of the engine oil and with extra soot but I believe changing motor oil earliest at 5K Miles while using a real 100% synthetic motor oil helps the longevity of the motor oil helping to save in the long run. Last I checked, a quart of Mobil1 0w20 Annual protection was the same price as Amsoil Signature Series (members price) which it’s a no brainer there.
Sent from above
Hopefully no arguing comes out of it but all in all everyone is going to do what ever they want to anyway and arguing will only boost an insecurity factor of ones intelligence. I just showed my 2cents and leave it at that except I’m going on a 5-6k mile change the next time lol
Sent from above
5k mile intervals is a great time frame.  Easy to remember ie: 5k, 10k, 15k and so on.  Plus you can rotate your tires as well and depending on how long it takes to put the miles on, change out wiper blades and cabin air filter.
One thing, from my UOA's showing great results is 7,500 miles is a good target as well. Since we have an 8qt sump, it isn't as bad for that mileage as it was for a 5qt sump.
Just food for thought.  :)
This is what I’ve been talking about all along, Mobil1’s best oil not even being 100% Synthetic is almost $3 more per quart than the Amsoil 100% Signature Series. At 3k miles Mobil1 Full Synthetic breaks down and turns black where it takes literally twice as long for Amsoil to “VISIBLY“ show darker discoloration which obviously proves the point, longer intervals saves money at the same time best protection available for our engines. A buddy of mine that spends enormous amounts on his race cars told me that 100% Synthetic takes much longer to break down than the Full Synthetic oils. I’m completely sold and especially since I’ve actually noticed a much smoother running engine since I’ve switched to Amsoil Signature Series. Here’s a pick of today’s Auto Supply store, Amsoil at $10 per quart versus Mobil1’ best, it’s a no brainer!
Sent from above
Sent from above
Brother if you don't know the why you will not figure out the KIND. I'm on point here and AGREED with you. How often does that happen. Gift horse bother, gift horse.
Now I'm starting to doubt what is meant by "kind".
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
