Randy at seating solutions has come up with a 2 piece design for the custom trailboss to raise the drivers seat. Excellent product, easy to install and he will answer any question you have. +1 (770) 401-9307 is his number his name is randy. Tell him I sent you over and he will help you out. My truck is the first kit with the “2nd design” of this product and is just what I needed.
This was the 1st thing I complained about, for high the TB sits I thought you should sit higher in the truck.
I'm desperately trying to figure out how to wire a power seat in mine, I can't get comfortable no matter what I do with the seat
Your right the seat is not very comfortable
  • 5 months later...
Would this work on the power seats? Even those have no decent camber adjustment...it'll spill you out of the seat but not tilt back enough to cup you in it.
Awesome. how much roundabout?
the new truck seats are way too low, I am 6ft tall and without power seat I have it would be impossible to get comfy...….
and why is foam so stiff in new ones? it could be tad softer imo…..
was so close to getting a custom TB for same price as my RST and so so glad I didn't!.....I probably would have brought it back..
I would like to raise passenger side 1 inch + tho
Edited by Dunn
To be honest you can buy the material, trim to size, tap the holes and get 8 longer bolts if you just want to change the height.
I think what needs to be looked into is changing the seat angle so they are tilted back a bit to cup the occupant.
  • 2 years later...
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
