Best Price On Tires
So I was all set on a zone 4.5 with 35x12.5R20 Ridge Grapplers in the fall.  Getting some sticker shock on that rubber though and second guessing myself.  whats the best place to go for a deal?
Yep, tires ain't cheap when your talking 35x12.50 x 20's.      I just recently got some TOYO Open Country R/T's  at a whopping $400 a piece!      I love them though,  so all worth it to me.
1 minute ago, amxguy1970 said:
Step down to an 18, it will be cheaper by a couple hundred dollars and look more appropriate to a truck...
Tyler
already have my wheels so the 20 is a must
I always watch my local auto/farm store ads. A couple times a year they offer buy-3-get-1-free deals. They mostly stock oem sizes. Either way, shop around and watch store ads and you can find a decent deal.
Do you have Discount Tire nearby? I think they will give you some $$ for your OEM tires if you trade them in with tread left.
I got the best price from ebay. I had a tire machine at my disposal so that helps.
I've used simple tire . com
They drop shipped to Pepboys who installed the tires for about $100.
Over all, I saved on tires, no tax, and free shipping. I would use them again. However, pepboys jacked up my wheel when they were training someone how to change tires--but they paid for the damages so I can't complain too much.
Take the KO2's...A set is $1300 at Costco before install. From ST it's $1180. Even with the increased cost of mounting from a shop outside of Costco, you still come out ahead.
I’ve found good deals online at discount tire direct and 4wheelparts around holidays. I think I’ve got free shipping from both places as well. Probably got some sales for the 4th as we speak.
Tirebuyer has them for $374 with free shipping TYD and an extra $80 off.
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 550 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
