2019 Paint blemish on tailgate
Has anyone had to have any type of paint issues warranted on their truck? I noticed a spot on the tailgate of my truck today, it’s a 2019 with 5,000 miles. It’s under the clear coat so I know it was something that happened at the factory. Kind of looks like a glare in the pics. Should I have any trouble having Gm take care of this? Thanks
Not sure what else to call it. Looks like someone brushed up against it when the paint was wet.
Gm's newer paint process is just plain terrible imo, not only is the paint extremely thin and brittle, but they seem to have a difficult time with keeping the surface free of contaminants before the bots spray the body.
My drivers front fender has the type of mark. I can only see it at a certain angle.
Same thing with this. Can’t see it at all angles. But now I know it’s there I stare at it all the time.
With any metallic paint, the shimmer or shine (or dull spots) often depends on how the metallic flake lands when painted. That is why silver's are very noticeable when you repaint a panel compared to other panels beside it. If the flake 'stands up' a slight degree more, it is very noticeable as a dark spot. If it lays slightly more flat, it shows up as a light or dull spot. It all depends on the air pressure used when painting. You'd think a factory shouldn't have issues, but they do.
See what the dealership says.
Just my . 02 opinion, but unless the clearcoat is bubbled off the color coat, I'd leave it alone. Sure dealer is repainting, no skin off his nose,  he gets paid for repair by GM on a set scale. I wish you luck in getting a costly, durable top line refinishing.
Think you have problems now, wait until after a repaint. Original finish is baked on electrostatic colored dust covered by a water based clearcoat that presently matches other panels perfectly in color and reflectivity of finish. The clearcoat/color has to be completely stripped to do it right (clearcoat does not adhere properly to clearcoat....that's why you can't fill surface scratches with clearcoat ) and take the panel down to the primer/reprime. Think they'll remove the handle hardware and remove and reapply new emblems or just tape around it? What you'll likely get is a quickie sanding and a spot reflash of a localized area with an acrylic enamel and dusting of clearcoat which will look great enough to get rid you for now......but, time and temperature will determine how long it remains intact. Come time to trade and the used car manager goes over it with an electronic meter to determine paint thickness on all surfaces and then it's time for you to fill out a damage disclosure and take a hit on the trade value.
    • Yeah I don’t leave ANYTHING just sitting supposedly maintaining my battery on a vehicle or RV for multiday periods. I connect a charger as needed to provide a full charge, then disconnect it and either monitor the battery or follow a set schedule for periodic charging.
    • Get the 5.3. I`m not a Ford guy.😉   I think these L84`s are less problematic than the L83`s. Certainly less than the L87.
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
