I know the K2 guys have one of these threads so I figured we should too. Think it’d be useful for others. Post pics of your setup! Make sure to add specs of the wheels/tires, spacers, suspension, rubbing/trimming...
I’ll get it started..
Fuel sledge 20x10 -19 (no spacers!)
Toyo RTs 285/55/20
1.5in leveling kit
Rubbing on the mud flap a lil before full turn
  • Like 14
Fuel Rebel 20x10 -18 Offset
No spacers
Nitto Ridge Grappler 295/55/20
Factory Trailboss Suspension
Slight Rub on mudflap on full lock.
  • Like 8
Method NV 305 18x9 -12 Offset
Cooper Discoverer S/T Maxx 295/70/18
1.5 Level (Trailboss)
  • Like 11
Level 8 Slam's 18x9 0 offset
Fallen Wildpeaks 295/70/18
4 inch Readylift
Slight rub in reverse on full lock20190527_104326_HDR(1).thumb.jpg.07cde885f7b49fd0a7dd85eaddcaff54.jpg
  • Like 4
- Fuel Coupler 20x10 -18 offset
- Nitto Trail Grapplers 35x12.5R20
- BDS 6 in lift
no rubbing at all
  • Like 9
18 hours ago, BevoXV said:
Caliper clearance!
I'm not much on the '19s but that is a sharp truck.  Really like the distinct black and white of it.
20x10 -18 Fuel Mavericks
6mm Bora hub and wheel centric spacers
Nitto Ridge Grapplers 35x12.5
2" Trail Boss Lift + 4" BDS Lift = 6" Total
Mud Flap bracket delete
Tied back the front of fender liner
Edited by BlackLS
  • Like 7
Stock at4 suspension
Black rhino chase wheels 20x9 +10 offset
295/55/20 Nitto Ridge grapplers
No rubbing
No spacers
  • Like 4
Thanks man! I appreciate it
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 495 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
