17 minutes ago, At4Life said:
So what's the tire size now?  And what leveling kit did u do?  I'm looking at the ready lift sst with those wheels n specs with a 305/55r20
Stock tire size at 275/60/20. I wanted to keep the tires light to maintain the smooth ride and didn't need the extra load rating. I'm leveled on a Readylift 2 inch bottom strut spacer.
I had 305/55/20's on my 15 Sierra All Terrain. Loved the look of that size!
That's what I had before as well. A 15' elevation edition. Looked great.
I know what you mean about not wanting to sacrifice the stock smooth ride.  I'm tempted to do the same and use some all terrains for a slightly more aggressive look and maybe a small spacer to give a better stance.
Which tire are u running?
Honestly, the stock Elevation 20 inch black wheels are really nice. Originally, I was going to just get 1.5 inch wheel spacers and run an all terrain tire with the stock wheels. However, I do a lot of driving with both kids in hockey and the winters are pretty harsh here. So for piece of mind I opted to get the new wheels to avoid spacers.
Right now I'm running with Duratracs. Had them on my last 3 trucks and they are hard to beat in the snow...i was hoping to get something less aggressive looking this time around but I couldn't pass up on the sale that they were on.
10 minutes ago, 73bronco said:
20x9 +1 Fuel Tech wheels wrapped in a 305 55 20 Nitto Ridge Grappler
Looking good, Love the fitment! Stock height correct?
13 minutes ago, 73bronco said:
20x9 +1 Fuel Tech wheels wrapped in a 305 55 20 Nitto Ridge GrapplerD0E0764F-F2DD-4127-957E-FFACA40E2621.thumb.jpeg.655975b5c9e085c51cb3385649ae877a.jpeg
Looks good. Any trimming?  All stock or leveled?
Thanks. Slight rub at full turn. Rough country 2 inch level with an extra 1 inch in the back
Thank you. 2 inch rough country level kit plus some inch larger block out back
Stock suspension, going to level soon
28x10 Asanti Black Label Apollo Wheels
Lexani tires 295/25/R28
No Rub
Edited by Bud On 28s
  • Like 4
No Rub
is this photo shopped?
No Rub
No photo shop, this is the photo of the truck in the shop getting them installed to see the before and after. We rolled it up to compare To stock size
Just now, Vince Rodriguez said:
WOW impressive. its not my style but it looks good, are you going to slam it?
Thanks! Not slamming it, but going to level it, drop the rear even with the front. I was told it will rub if I lower the front
20x9 Fuel Vandals +1 offset
33x12.5x20 Nitto Ridge grapplers
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
