Forgot to update. Ran into a deal that I couldn't pass up. Guess I'll have a summer and spring set
New setup (top)
Fuel Seige D706 20x9 +1mm  275/65/r20 Ko2
Old setup (bottom)
Fuel Vapor D569 20x9 +2mm 275/65r20 Wildpeak ATW3
I don't understand everyone's obsession with Fuel wheels. They're ugly and expensive. I HATE the massive center caps on them so they can sell them as dual bolt patterns to save money.
Is anyone running 305/70R18 with a +1 offset and 5 inch backspace on there setup. I am currently running the stock set up on my 2020 silverado 1500 6.2 Ltz with bilstein 5100 front struts set to max setting got about a 2 inch lift overall set at the max. I was squating in the back so I added a 2 inch block and bilstein shocks in rear. Want to upgrade my wheels and tires now just not sure how big I can go I am willing to to cut some plastic and remove the mud flap bracket but don't want to have to take the crash bar out just yet maybe in the future. I also tow a 8500 lb camper trailer a few times a year I will be getting air bags soon for that.
70614737286__F3352034-6DF6-411D-9D17-2A05CDD7F5AC.thumb.jpeg.c4c9d3d0f4f01b840cf0b2df21e50992.jpegMickey Thompson Baja Boss A/T 305/55R20 (33.4x12.3). Western Edge Gloss black, milled accents, 20x12, -44 offset. I have a set of 5.
These tires do not rub with stock trail boss suspension (removed blocks in the rear), and I’m running the Bilstein B8 5100 trail boss struts up front, regular Silverado shocks in the rear. Rides really nice.
The tires poke out 2” past a 2” flare. It was either fender lights or flares with more than 3” of protrusion, so thanks, Virginia, I’m running a fender flare instead of a light, because this truck is not a 2500.
Edited by s10dragracer888
i'm in the market to get new tires for my 2020 LT TB since my original tires are making a TON OF NOISE. i'm looking at the mickey thompsons. are these tires quieter than the wranglers? i want an aggressive look with less road noise than the oem tires. thanks.
Much quieter. I had the 18” Goodyears and they started screaming at 25,000 miles. I’ve put 20,000 on my mickeys and they haven’t worn much, if at all. They’re load range F (12 ply), and I run about 42-44 psi in them.
The M/T Baja Boss A/Ts are a tad bit more expensive than the Falken Wildpeak AT3Ws and the BF Goodrich KO2s, but I’ve had all three. I loved my Falkens, but these Mickey’s are my favorite. KO2’s wear out too fast and cup real easy
i pulled the trigger on the Baja Boss A/Ts since my local AAA shop matched the ebay/discount tire 20% that's currently running. i get them put on early next week. looking forward to the 'quieter' ride.
2019 LT TB. I’ll be riding stock suspension. Read through a lot of the thread here and it seems like I’ll be good with a 18x9 +18 Moto Metal Mo970 and 33x12.50 Ko2s, right? No rub? And if it’s on the flap I’ll just cut some.
2023 RST Z71. 2/4 Maxtrac Lowering Kit
24x10 +25 Escalade Platinum Oversized Stocks with 285.40.24 Toyo Proxes ST III. No rubbing, comfy ride.
On 3/25/2023 at 12:08 PM, 85CJ said:
Cooper Discoverer Rugged Trek - 275/60/2012EDAE92-7020-4C85-A279-7A16F534CF6B.thumb.jpeg.9cd4df34edd447e8962e7f530464c2b4.jpeg01A2D340-7F74-4010-9C64-4FEB9AED72BD.thumb.jpeg.23e35271d813b2067dac8f263dbfa0d7.jpeg
considering these tires for myself.  notice any decrease in power or mileage with your duramax?  thats what i have also so just curious
New setup (top)
Old setup (bottom)
Rims:
Fuel ammo bronze 18×9 +1 offset
Tire:
Nitto terra grappler g2 295/70R18
Bilstein 5100 front struts set at max height and Bilstein 5100 shocks in rear with 2 inch block. About a inch and quarter rake in the rear. No rubbing I cut the mud flaps and removed the mud flap bracket behind wheel liner and pinched the wheel liner back with self tapper to the crash bar.
Edited by Midnight Blue 20 Silverado
How are you liking these?  Loud? Smooth?
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 871 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
