On 8/27/2024 at 3:51 AM, dfanzz01 said:
Stock suspension
305/45/22
Asanti Mogul 22x9.5 +25 offset
No rubbing, no trimm
 22s just look so good on these trucks. I bounce back and forth abt returning to 20s but just can't
Edited by Russ757
  • 1 month later...
2020 Silverado Custom
2.5" leveling kit
2024 GMC AT4X stock 18's
Goodyear Territory LT275/65r18's
NFab nerf bars
Ranch hand legend for GMC Sierra (got it for free as a dealer pull off on a trade in truck)
UWS low profile tool box
Mamba racing waste gate actuator spacer
Afe charge air cooler piping
Afe cold air intake
Jb4 plug in tuner
Current Setup:
- @bdssuspensions 4" Coilover Lift Kit
- @toyotires Open County R/T Trails (37X12.5R17)
- @lockoffroadwheels Onyx@fueloffroad Variant Bronze wheels (17X9, -12 offset)
Just replaced my OEM 275/60/20 Goodyear Trailrunner ATs on my 2019 RST Z71. Got 6 years out of these things and 40K miles of good performance. With the snow storm hitting in DFW, I figured it was time to replace them... esp. since every time the roads were wet, I had to run in 4A. 😂
Put on some Nitto Terra Grappler G3s, same OEM size - 275/60/20. I'll post some pics soon. 3-peak rated and man they ride just as quiet as the Trailrunners did. But serious bit on the snowy/icy roads around DFW the past few days!
Considered doing 285s, but I didn't want to pay about $80 more per tire just for an extra 10mm of height.
285 is the WIDTH, not the height. 60 is the percent of the width that the sidewall height is. 20 is the rim diameter.
Yes, I understand tire sizes. I meant going up to 285/65/20s.
You mentioned NOTHING about going from a 60 to a 65, only 275 to 285.
In case anyone else is wondering if 285/65/20’s would fit a stock truck with no lift. They do.
2022 crew cab, standard bed. Got rid of the stock 22’s
  • Thanks 1
Nice! What price per tire did you have to pay for those?
When I looked at 285 vs 275 the price was about $80 more per tire for the 285 set up. 🫠
On 1/7/2025 at 6:27 AM, PureZ71 said:
Current Setup:
37s work so well on silverados.
I wanted those OEM wheels, so I found a lightly used set with those tires for $2k CAD but tires are definately pricey.
Also have noticed my fuel economy has gone down quite a bit from ~9L/100km to ~11L/100Km. But with these tires my speedo is also off which will also throw off the fuel economy calculations.
On 1/7/2025 at 9:27 AM, PureZ71 said:
Current Setup:
To clarify. As I see the z71 badge, was your truck lifted prior meaning this is 6" total lift or 4" from a non lifted?
I ask because you ran the ready lift 2" previously I believe and liked the look of that
Hey Russ!
My truck is a Trail Boss so it comes with a 2' lift from the factory. So when I added the 4' BDS kit, which is for Trail Boss and AT4 only, it raised it 4' on top of the 2' factory lift. So compared to a non Trailboss, its a 6' lift.
Correct I did have the ready lift 2' sst kit before to fit 35's. I went to the BDS kit so I could add 37's.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 766 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
