Interested as well, been thinking about adding one to my truck.
Same, but most plug into the 4pin trailer plug, which I dislike, mostly because that plug cover opens from the top, but secondarily I do not know if it activates the trailering mode on the truck.
I have thought about wiring in another 4pin flat behind the bumper, just splicing off the loom, but that does not answer the question on the trailering application.
I did,  but I only wanted a solid red led ( I don't care for the turn flashers, back up etc of them) ... so I  hard wired the running light / stop light wires of the led strip into the taillights.  I wasn't a fan of using the trailing plug.. looks crappy.
On my old truck I just bought a red led strip from superbrightleds and wired it in... the amazon I got was cheaper..
3 hours ago, PhilB said:
OPT7 has a tow package module to deactivate the tow package when not towing.
http://www.opt-7.com/tow-package-module-for-redline-led-tailgate-bars/
So it looks like you have to use this if you have a tow package, backup camera or backup sensors?  I was thinking about this module, but now I’m not sure it will work.  CURT 55384 Replacement Vehicle-Side Custom USCAR 4-Pin Trailer Wiring Harness https://www.amazon.com/dp/B0009FJ38Q/ref=cm_sw_r_cp_tai_dfLoDbHKW42HY
I bought a 7-Pin to 5-Pin harness, for behind the bumper, just for this reason.  I also bought a 5-Pin connector to install on the tailgate LED light bar that I end up getting, when I finally decide on which one I want.  I also purchased a 4-Pin connector for my hitch brake light, going to tap into the 7-5 harness, and rig both 4 & 5 connector to operate for brake light ONLY (no turn signals).  IF I get a light bar with reverse light capability, I will be using them on the 5-Pin.
I think you have to use the module to deactivate the tow package.  You would still plug it in to the CURT adapter.  Using the CURT adapter is the way to go to avoid hard-wiring the LED strip.  On my '14 I did what Ravenkeeper did and went with the 7-pin to 5-pin connector.
I have the Putco Blade and used the Putco "Plug and Play" harness which connects to the trucks tail light wiring harness not the trailer lights.
I tried the Curt harness from Amazon but my truck did not like it, my screen kept alternating between "Trailer detected" and "No trailer connected" over and over until I disconnected the harness. Also tried plugging the light directly into the trailer plug but had the same problem.
Putco harness info: Blade Quick Connect Harness for 2019+ Silverado/Sierra 1500 SKU: 529005
Link https://www.putco.com/529005
Edited by BlackLS
  • Like 7
Looks good .   Pricey...
Do you have a trailer brake controller factory
Yes I do
I like this one, it seems to have a lot of good reviews and they last, just really pricey and by the time you add the harness you are $275 plus.  Such difficult decisions, the opt7 is $90, and has over 1500 reviews on Amazon, but alot of people gave it 4 and 5 stars, but they also said the lights didnt last long! ugh..  Not sure I can convince my wife to let me spend $125 for tail light tint and another $275 for led light bar... ouch! lol
Did you remove your entire tailgate for the installation
I have a GMC multi pro the wiring harness to unplug is not the simplest
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
